Any body knows
thanks
Sent from my SM-G900P using Tapatalk
So any 07 and up will fit 2013? Any changes on sprocket or something?Yes.
Additionally, 07+ zx6r wheels are compatible.
I dont have abs, so just use my old rotors?'05 and up for the front wheel and '07 and up for the rear wheel. The '05-'06 rear wheels fit as well but require a bit of modification because otherwise the caliper bracket drags on the rotor bolts.
You'll probably want to transfer your pickup discs from your wheels the whatever you buy if they're pre-2013, if you want your TC and/or ABS to continue to work.
It has nothing to do with rotors, but yeah you can use your rotors or if you get others they'll have to be from a 2013+ because they previous gens used smaller rotors.I dont have abs, so just use my old rotors?
Thanks. I will get my wheels now.Yes. The wheels are the same but the rotors are different.
Yes! It's used in conjunction with the wheel sensors to pick up speed. So when you take your rotors off to move them to the other wheels you're getting, be sure to move those discs as well.Oh the one on the left side?
When you said "move those" do you mean just the third disc in the front right? The back has a rotor only?Yes! It's used in conjunction with the wheel sensors to pick up speed. So when you take your rotors off to move them to the other wheels you're getting, be sure to move those discs as well.
