I was ridding my bike the it cut off then I tried to turn it back on the oil light was blinking then I put 4 quarts of oil in it then we I tried to start it the oil and FI ligt blinks help me plss
4 quarts.... man the bike takes 3.1-3.3 quarts; Fix that. This has nothing to do with the oil. Its the throttle, it needs to be adjusted. Also get the recall done. Thats it and you'll be fine
1) DOWNLOAD THE MANUAL
2) Learn how to check the oil -- it has to be vertical, not on the side stand. If you added 4 additional quarts of oil (thereby having 7 and change in the cases) you are in serious danger of damaging the motor if you do manage to get it to start. Drain the oil and re-set it to the correct level. Immediately.
3) Whoever the 'we' is that was helping you with this.... don't consider them a good source of mechanical advice.
