1 - 7 of 7 Posts
· Registered
2006 zx6r 636 ninja. First bike, it's a bit of a project.
Recently got some really helpful advice on here so going to ask another question. Need to replace my oil pan on my 2006 ZXR. Looking at a used one that says it's to my bike but differs a little bit such as oil drain plug location among a couple other small differences. I'll attach photos of the used pan I'm looking at.
Font Rectangle Screenshot Metal Circle
Watch Clock Font Analog watch Measuring instrument
Household hardware Gas Composite material Cylinder Metal
· Super Moderator
If it’s visibly different than your current OEM pan, I would recommend passing on it. It may be possible to get your current damaged pan repaired, but it would be better to have a machine shop do that work.
Oil eventually works past pretty much any kind of glue or epoxy. Having someone MIG/TIG weld up any cracks or holes would be a much more effective solution.
· Registered
2004-20-23 636
Ya. Doesn’t look like the correct 06 pan to me. Like RJ SAID. repairing is super easy if it’s just a cracked or stripped bung. Post pictures of your damage. Chances are Find a good tig welder and they shouldn’t have much of a problem. I just repaired a very cracked one. He hit a brick in the road split it about 6”. Weld and smoothed it’s good as new. Prob like 100$ fix at a local welder.
· Registered
Discussion Starter · #6 ·
The pan is cracked in several places around the drain hole and up the wall. Cant really see in a photo. Looks like previous owner tried to put a coat of flex seal on the outside of it 😆 🤣 😂 😹 it's a total mess......SMH
· Super Moderator
The risky part with the used part, is you run a chance of it not being flat, or already cracked or stripped out on the drain plug.... well worth your time to inspect it very carefully before installing it.
1 - 7 of 7 Posts
