I am currently doing a ton of maintenance, valves, cam, brake fluid change(done), coolant, smog block off plates install(done), throttle & clutch cable lubrication, air filter clean, spark plugs(done), new friction plates(done), new crankcase cover(mine was scratched enough to be leaking; done), new CRG clutch & brake lever, and finally oil change(1/2 done). I also have new fairings from Monster Fairings on order hopefully they look as OEM Plasma Blue as possible and quality unlike my last Chinese ones with the right side flying off at high speed, and installing an Under Steering Bitubo Steering Damper. Naturally with all this work I want it cleaned up and like new as possible, doing it all myself. Anyway, so yeah anybody know if I can just spray off the underside of the tank area and underneath the seat areas?(After removing the battery of course.) It's incredibly dusty under there.
TL;DR - Is there basically an easy way to clean everything up underneath the tank and seating areas? By say, spraying it with water without any damage to wires, etc? I'll likely be just wiping everything down with a bucket of soapy water and cloth/dish brush but I am just touching all possible avenues. Thanks.
