2006 Kawasaki Ninja ZX6R 636, black, only 11,268 miles, well maintained, no leaks, looks good and runs perfect, ready for the track or the street! Clean title, has current Virginia inspection. Located in Bristow, VA. $6000.
Specifications:
Engine size 636cc
Engine type 16v in-line four, 6 gears
Fuel delivery Fuel injection, two injectors per cylinder
Front suspension Adjustable preload, compression, rebound
Rear suspension Adjustable preload, compression, rebound
Front brake Twin 300mm discs
Rear brake 220mm disc
Front tire size 120/70 x 17
Rear tire size 180/55 x 17
Modifications:
Braided stainless steel brake lines (front and rear)
Front and rear sprockets (OEM specs)
Brembo 19RCS Corsa Corta front master cylinder
Tank grips
Servo buddy
Rear cowl
LED turn signals and brake light
IRC quickshifter
Engine cover protectors
Front fork sliders
Frame sliders
Lithium Ion battery
Battery tender connector
Samco silicone hoses
Tail tidy
Original Parts Included:
Passenger Seat
Front master cylinder
Under seat OEM tool kit
Turn signals (front and rear)
Exhaust valve servo motor
Service manual
Recent Service (within 100 miles):
Coolant flush/replacement
Brake fluid flush/replacement (front & rear)
Changed Oil (Fully Synthetic)
Replaced Oil filter
Replaced Air filter (OEM)
Replaced Brake pads (front and rear)
Replaced Tires with Dunlop Sportmax Q3 Plus Tires (100 miles wear) and tire balancing front and rear
Replaced Spark plugs
Replaced Thermostat
Rebuilt brake calipers (front and rear) w/new seals
Rebuilt water pump w/new mechanical seal and gaskets
Replaced chain
Cleaned fuel injectors
