Hi all!
I've bought a 2005 zx6-r with 28k km on it as my project bike. I seriously considering adding a supercharger and aiming for about 200 engine hp.
The supercharger selection is as follows:
1. AMR500 (I saw a video of a guy who put it on 675 Daytona and got 225 HP) - aiming for about 7-9 PSI - dirt cheap, plenty available & pretty reliable. Will be run with ceramiser oil addition to keep up with 18k revs max (1.5:1 ratio)
2. Some refurbished Eaton R410 or M62 or similar (depending on size & performance)
3. Too expensive but maybe possible in future: Rotrex C15-60
I don't really need that much HP, but I just love tinkering with bikes. This will be my first big project, that's why I'm going to do it with a mechanic shop specialized in tunning (mostly cars). I'm thinking about using full bazzaz package with QS / TC to tune it. Of course intercooler as big as possible is going to be in place as well 8)
Basically I want to change my Horse Power to "Unicorn Power" (very dangerous animals, with more power).
List of other mods that I plan to do / or I'm already in progress of making:
The bike will be ridden mostly in the city to my office (though I rev it often to 12k cutoff, mostly because of acceleration - I rarely largely break speed limits
I also brake hard & lean as much as possible on city streets. I don't write aggressively in traffic / limited visibility or bad conditions. I do not intend to ride in rain. Track days & some longer trips will be limited to only few a year.
I do not want to buy liter bike a this time. I do not want to bike more modern bike at this time (just love 05-06 ZX-6R looks).
I will upload some pictures of already done stuff later
- Full led projectors (almost done, need to adjust the light beam cutoff)
- Automatic DRL/low/high beam depending on ambient light (in progress, using some premade module right now to switch between DRL/full led)
- Adjustable DRL color, adjustable DRL + headlights intensity (possibly arduino based module + mosfets & smart leds for DRL) + controls (maybe Bluetooth app?)
- DRL blinkers (done, will be replaced by custom color DRL)
- Custom aluminum exhaust piping after cat
- Probably some DIY / custom double slip-on / Akrapovic (I love the looks & sound of underseat exhaust on 05-06)
- ZX10R rear wheel swap for 200/55r17 or 200/60r17 tire (bought & dismantled rim, need to order correct bearings or machine rim to match 52mm bearings from 636, also I'm missing information about axle spacer length on 636 - not sure if it will fit zx10r rim? Perhaps I should consider axle swap as well)
- Accesory chain tensioners (more precise & easier to use ones)
- Fairing replacement (already in shipment)
- Front & rear suspension replacement from 2018+ zx6r (Are they worth it or should I just refurbish OEM ones?)
- Steering damper (done)
- Double rear cameras (possibly instead of mirrors) + 5"-7" screen that will display them both
- Integrated tail light & blinkers (done)
- DIY speedo healer (I will need help with that, I do not own oscilloscope)
- Flashing led when stopping OR slowing down (see 14.)
- Hydraulic clutch conversion (in shipment)
- Accessory master front & clutch pump (Brembo RS19 copies)
- Accessory rear pump (Brembo copy)
- Darkened/smoked headlights/blinkers/rear lights
- Tire pressure & temperature sensors + display (waiting for tire replacement)
- Louder horn (done, though I want to revisit that one - it's still to quiet
- DIY lithium battery with additional small supercapacitor pack
- Underseat socket for easy charging of battery
- Hermetic sealed connectors for most exposed / non sealed connectors (blinkers etc) - (done)
- Engine, supercharger & exhausts painted in black (if I'd like to ride it sometimes without fairings, and to add to the general look&feel 8) )
- Stunt cage/frame sliders + stunt rear pegs in place of passenger set (I'm having troubles finding that items for sale and nobody I know makes them)
- Underseat license plate holder + custom lights
- Easily accessible horn button (additional, more ergonomic one - super useful for street riding. Oem horn button is too far away from my thumb even after adjustments - I need quick access for emergencies)
- Oil cap with DIY temperature sensor?
- Pulstar plugs (in shipment)
- *DIY custom build speedo (this is really tough & time consuming, since I'd had to decipher original one
But perfect version I Imagine would have integrated camera display on 7+ inch screen, coolant + oil temps, light adjustments, fuel map adjustments, TMPS pressure + temps, error code reading built-in, GPS speed etc - sky is the limit here
