1 - 3 of 3 Posts
I recently adjusted my valve to be within factory spec. And after reassembly when I rev my bike on the downward rev it pauses at 3.5k rpm and slowly goes down from there. I don't think it has anything to do with the idle Bc I've adjusted that several times. Possibly the throttle cable? I've adjusted it but it hasn't solved the problem. I'm think maybe something to do with the throttle body but I'm not too sure. Anybody else have this issue?
Sounds like something is hanging up. Try tracing over everything you moved/removed during the valve shimming, then check it all again.... And again. Ensure your throttle cable is routed correctly and that nothing is getting in the way or inadvertently hanging in the way of the throttle body.
Oh, welcome to the forum too.
1 - 3 of 3 Posts
