1 - 4 of 4 Posts
Due to some damage to my 03 zx6rr's left fairing I had to cut and modify it a bit. Now the charcoal canister is a bit of an eye sore so I'd like to remove it(i live in az). I was wondering what all I need to do to correctly remove it so that everything else still works properly. Thanks.
I used some vacuum hose plugs that I got from autozone and cut the harness that connects to the valve and connected the wires.
Time to time you will smell some gas fumes once your remove the charcoal canister. That is one disadvantage of removing it.
1 - 4 of 4 Posts
