Please help! I have a 2003 Kawasaki Ninja ZX6R, if i'm riding my bike and the rpm's hit around 8000 to 9000, when I come to a stop and the rpm's go back down, the bike begins to idle funny and the rpm's begin to drop below 1000 until it dies out. I can keep it from dying by giving it some throttle when i'm coming to a stop.
I put some Seafoam in the gas tank and rode the bike around for a good bit to see if it would fix the problem; everything seemed to run better except it still died out if the rpm's got to high. It never dies on me if I keep them low and ride at normal speeds. I also wanted to run some sea foam through a vacuum hose but wasn't sure which one to use so I never did it but when I was looking at the hoses I notice that I was missing a hose that attached the the bottom left of the air filter housing/air cleaner housing.
So my questions are:
-Where is the hose that is suppose to be attached the the air cleaner housing connect to on the other end? (Pics would be awesome!)
-What vacuum hose do I use to poor some Seafoam in? (Pics would be awesome!)
Do you have any other ideas on what it might be that is causing my bike to die?
Please Hepl!:hail: Thanks in advance!
