Hello Everyone,
Hope everyone is doing great. I bought a new motorcycle and am new to motorcycles but my zx6r won’t start.
The run down:
I was sitting at a red light, the light turns green, I go to slowly let go of my clutch and I stall. I go to start it again and it won’t start.
It was a pretty hot day, the gauge cluster has 246 degrees flashing which I’m assuming isn’t a good thing?
i turn the key and the gauge lights, brake light, and hear clicking (assuming that the throttle body callibration). I believe I also hear the fuel pump priming. Fuses look good, I just got the replacement kickstand switch so I’m hoping that fixes it but probably won’t. I’ll be replacing my battery tomorrow.
When I go to start the motorcycle I don’t hear anything. The motorcycle doesn’t try to turn over, no clicking noise. Just the throttle body calibration and I think the fuel pump when I turn the bike on.
I checked the battery and it’s at 12.7 volts, replaced the starter relay, and also checked the kill switch. None of that fixed it.
when this stsrted I also noticed that the kickstand would kill the bike in neutral regardless of whether clutch is pulled in or not. Neutral light turns on.
The bike has get bump starter, once bump starter, everything shifts and stuff normally. Just cant seem to figure out why it won’t start. When I go to start it, kickstand is up but it still won’t start
The run down:
