Meh, probably cheaper to rebuild what you have and you wont have to fab up any mounts or splice a wiring harness.
Meh, probably cheaper to rebuild what you have and you wont have to fab up any mounts or splice a wiring harness.2001 Kawasaki Zx6r (zx600j)
Hello everyone , i’m currently in the dumps . Went for a cruise today and about 90mph i lost power and heard my rod knocking BADDD!! I was wondering if anyone had info on what motors i can swap into my bike or parts from other motors that are compatible. Any help is greatly appreciated 💪🏼
My assumption was that the chances of finding an engine to just throw in that worked flawlessly out the gate and required nothing would be next to zero, requiring parts/time/labor anyway (which it seems you have plenty of experience with if you have stacks of them). So, buying an engine, then buying another or abandoning that idea would be more expensive than the rebuild anyway.come on..........
fucking dolts...............
It is absolutely going to be cheaper to just buy a used engine from any J model ZX6R (2000-2002) or ZZR600 (2005-2008) than it is going to be to buy a new crank and rod and all the accompanying needed parts then do the work
that said........ what you get for yoor money time and investment is likely a better outcome to buy new parts and install them in your non windowed set of cases with the VIN that already matches your motorcycle title (ie engine number is required on the title transfer and when it doesn't match they refuse titel transfer- and to change it on the state records you need the a copy of the title from which the engine came.......... that is the hassle and expense here in Minneshithole as a result of all the stolen motorcycles to chop shops....maybe where you live is different?) but you have to pay fees to change that stuff
new crank.......................................................................................................................................... $1200
new rod............................................................................................................................................. $220 each x (?)
all new rod bearings, crank bearings, oil pump, gaskets, seals, piston rings........................ $800+
Did the piston hit the head?
did the valves get smacked?................... $45 each on intakes....................$75 each on exhaust
don't forget about the oil/filter, coolant, new plugs and everything else it will need---including a proper tune up service
You could easily and quickly add another $1000 or more
and then depending on miles and use/abuse.....what do all the other wear out parts look like, transmission, shift forks, clutch etc.....
then how competent are you to actually do the work properly? or do you have to pay someone to disassemble, clean and reassemble?????????
If you go out and just buy some used engine off the internet there is no telling what is going on with it, how it has been used and abused and neglected.......... I have stacks of them in my shed that were worse than the engines they were supposed to replace
but once in a while you can find a decent one, Do you feel lucky? well do ya?????????
Exactly. I said cheaper because I have seen guys buy several used engines this old just to end up worse off. I guess technically the initial cost will be likely twice maybe 3 times. . But twice the money for a brand new fresh built motor versus gambling to loose that half on buying junk. In my mind that sounds cheaper. But I have rebuild prob hundreds of engines and assuming I’d be doing the work myself . But who knows. Maybe he gets lucky.My assumption was that the chances of finding an engine to just throw in that worked flawlessly out the gate and required nothing would be next to zero, requiring parts/time/labor anyway (which it seems you have plenty of experience with if you have stacks of them). So, buying an engine, then buying another or abandoning that idea would be more expensive than the rebuild anyway.
OP could otherwise buy another used bike for the same or slightly more than what it would take to replace all those engine components. Bonus points on a same model/year so he can use his current bike as a spare parts/donor as necessary.
Oh man, I sure do know what a Romper is. In fact, if a guy wears one it's called a Rompim (Romp-him). It was a huge thing like 10 years ago.Well. You do have a point there. I helped a lady with a flat once. And when I went to Jack it up I noticed a whole grown man sitting in the car. I thought she was alone so took me by surprise so I said. “Are you just gonna sit there while I do this”. He said. “Omg you’re so right. That would be so dangerous if I stayed in”. He jumped out wearing what I later learned was a romper. Pranced over to the curb and sit and waited.
He missed the point of my smart Ass comment.
do you know what a romper is?
They used to tell you how to adjust valves in the owners manualsSurly to god there is more than 1% of men that could manage to rebuild a motorcycle motor? Hell my 19 year old boy completely rebuilt his gixxer motor 20k miles ago and has rebuilt least 4 car motors and I call him a moron several times a day. You make it sound like rocket science. I mean I hate everyone also but has the population really got this bad this quick that a decently capable man can’t rebuild a motor for the first time and not fuck it up? Jesus all knowable learnable information can be accessed with a cell phone lol
But then again I did show a grown man how to use a ratchet wrench. And another how to pop a bicycle chain back on just in this last year. So maybe I’m giving more credit than is due.
It would be quite an accomplishment to drink the electrolyte from an AGM battery…They used to tell you how to adjust valves in the owners manuals
Now they tell you to not drink the battery acid..........
case closed, yes..... people are that fucking stupid
Case in point...............Well. You do have a point there. I helped a lady with a flat once. And when I went to Jack it up I noticed a whole grown man sitting in the car. I thought she was alone so took me by surprise so I said. “Are you just gonna sit there while I do this”. He said. “Omg you’re so right. That would be so dangerous if I stayed in”. He jumped out wearing what I later learned was a romper. Pranced over to the curb and sit and waited.
cordless drill......It would be quite an accomplishment to drink the electrolyte from an AGM battery…
Just make it into a challenge on tik tok or some such….cordless drill......
the dumbs would find a way
