Hi guys, I bought myself a 2001 zx6r a few weeks ago and I noticed while I was out that the oil was low. I topped it up and drove home with no issues. When I got home i checked the bike and l noticed the oil level was a lot higher than it should be (yikes) im guessing the bike was still warm when I filled it. I removed the oil and put fresh back in but 4 days later the bike just doesn’t feel right. It starts and rides as it should but I did smell some sort of burning the day after and now im worried I’ve done some damage. There might be a slight loss of power but with it being a new bike I’m not really sure. Only thing I’ve noticed is theres a lot of white smoke during the start up and the neutral light stays on but very dim if that has anything to do with it. I’m currently using it for work and I don’t want to do anymore damage than I possibly already have so any help would be appreciated
You flooded your air box with oil. Lift the tank pull the air box out clean all the oil. While you are there stick a new air filter and plugs in it.
how over full we talking here? If the motor isn’t knocking then you prob dint foam it up enough to oil starve. But your crankcase breather tube probably filled the box.
It was well above the top line of the sight glass unfortunately. There was also foaming on top of the oil but I removed and changed it as soon as I noticed hoping I hadn’t done any damage to the bike. I’m no good with the mechanical side of things I usually let my local garage sort any problems I have not that I’ve had many. I was just wondering if it would be ok to ride the bike in this state? I have work tomorrow and I need to use the bike to get there but don’t want to ruin it anymore than I already have. And thank you for answering it’s been stuck on my mind since it happened kinda hoping nothing would come from it
Well top of the line isn’t a crazy amount over. You are checking with bike level right?? . Not ideal to ride it but prob want destroy it (if it’s what I’m thinking is your problem) It’s really hard for me to know how much oil it puked into the air box. It’s only a few bolts tho to Check. Pop the side cover on the tank lift the tank and remove the air box lid. Clean the oil out of the air box and throttle openings as much as you can. Hopfully the filter isn’t to drenched but dap it with a towel. Filters should have oil anyways so prob be fine to reuse the filter.
The smoke is just the oil getting sucked in with the air and mixing with the gas. So it’s not great on your plugs. Everything else I’m sure will recover. If it’s not knocking or rattling then you’re good to go. You’re just basically running two stroke (premix) gas in a four stroke. Prob why it feels underpowered. You could prob keep riding it and it will eventually burn all the puked oil out and stop the smoking. Your plugs should probably be changed soon tho. They may start fowling with all the oil in there.
keep in mind there is a lot of “probably” in that.
I filled the oil just under the top line while the bike was upright but I’m guessing she was warmer than I thought because the oil level was well above the top line by the time I had got home let it cool properly and checked it again. Thanks for the info hopefully the weathers a little nicer tomorrow so I can give it a good clean up before taking it to a garage. I’m thinking a service would probably be the best thing to do they can at least tell me if there’s any damaged to the bike or not. Thankfully there’s no rattling or knocking and the white smoke from the exhaust wasn’t half as bad this morning but it’s definitely a bit slugish in 2nd and 3rd but not to noticable. I’m hoping there’s just a bit of oil in the air box as you mentioned. Appreciate the help buddy I’ll come back here and let everyone know the outcome so there’s at least a post for someone to check in future if they have the same problem I had. Thanks again
If you're not doing any stunting, the tolerance for an overfill is pretty stupendous. I wouldn't want to go long term +1 quart, but anything less than that is unlikely to have long term impacts. Scumbag is spot on. Cleaning out the air box and swapping the plugs is relatively simple maintenance and something anyone should be able to do at home with simple hand tools..... or you can pay the shop rates (>$100/hr) and wait for them to get around to doing it for you.
There is an old lady lives across from my park entrance who’s husband past away couple years ago and she doesn’t have kids so kind of on her own. Anyways I keep an eye on her. She drives this little Honda and the other day she pulled in when my wife was checking the mail and my wife calls me and says her car was a smoke machine. I went over and brought it over to my garage. She had just went that day and got an oil change. I have a 5 quart drain pan and it filled it up almost 3 times. Evidently the jiffy lube place change her oil but forgot to drain the old oil. And when I say the drain plug was tight that’s a huge understatement. Idk what gorilla installed it but he must of been a big one.
All the symptoms you are describing is from oil puking in the air box. Check and make sure the oil doesn’t have coolant and coolant doesn’t have oil and your temps are staying normal. Very good chance you have no head gasket issues. Like RJ said it takes a decent amount of overfill and riding to start catastrophic damage. The biggest issue is the oil lever is too high and being sloshed around by the crank and foaming it up. Foamy oil want pump and lubricator the upper part of the motor.
so if your oil is clean and staying at the same level. Coolant is clean as staying at the same . Temps low. No ticking or rattling now that you have the oil level fixed you are probably 99% just fine.
with the white smoke at start up does it smell “sweet”. I’d probably check that coolant level asap and make sure it’s not loosing coolant. There is likely hood you do have a leaky gasket and that smoke is coming from burning coolant
but Hopefully
the reason it does the smoking first thing is while it sits there that extra oil in your air box has time to drip and run down into your throttle body openings so on first start up you are burning a bunch of oil with your gas and then as you get going it’s then just mostly burning fuel and air.
but Hopefully
The coolant level is definitely something I haven’t checked and don’t know how to check. How would I do this please? I’ve been keeping an eye on the oil and it looks fine and staying at the same level so that’s a good sign. Once again I have no idea how to check the temps of the bike I’ve only had a it a few weeks and I can only a see a temperature light on the dash and that only comes on when I first turn the electrics on. There was a weird smell (unsure if it was sweet) coming from the bike the day after I put to much oil in but seems to be fine ever since. I’d like to add the bike has made a ticking noise since I purchased it. I just assumed this was the same issue I had with my 05 r6 sounds like it’s coming from the dash area but never had any issues. Would the ticking come from the engine? Sorry for all the questions I’m just trying to learn more about the bike. As you are probably aware I’m no mechanic or anywhere close I just love riding them. thanks again
Everything ticks. If the temp light isn’t coming on then you’re good. It’s called a “dummy” light it will only come on when it reaches unsafe temps. If it does you need to shut it down and let it cool. . I can’t remember if your year has a digital read out. Someone in here may. You may scroll through the dash settings and see if one pulls up. To check the coolent tho ya just simply remove the radiator cap make sure it’s still full and stays full. I get my years mixed up till I’m looking at it. 99% sure yours is on the right side below the left clip on. You may have to pull a push pin and lift that side of the dash filler plastic to actually see the cap tho. Then it’s just simply taking it off and looking. Should be full. Your overflow jug should be half full ish. It will have min and max fill lines on it. You can usually get to the overflow jug without lifting the plastics so just seeing that it’s got some would be a decent start. Don’t confuse the overflow with the radiator. If it’s a plastic screw on lid. (Like a soda bottle) then That’s your overflow. The radiator will be aluminum and be more of a wing shape than round and will just turn a half a turn or so to latch. Make sure it’s latched back tight. They can be a little tricky being there a little hard to get your hand down. If it’s not tight it’s gonna steam and leak coolant.
this being a older bike and new to you. It would be a good idea to have a mechanic look it over good. Give it a fresh go over. Coolant flush. Spark plugs,filter, brake pad wear and brake fluid is always a good idea to flush and bleed. Every year is recommend i usually don’t stick to that honestly but least every 2-3 tops on my personal stuff. Check your chain slack. Just a good visible inspection by a guy who works on bikes for a living. It may cost you a little now but that could save you a ton in the future. That or get you a service manual and give it a go yourself. But I’d recommend having it all done first by someone who knows what they are doing and then you be aware of how it is and when you do routine look overs you will notice anything that’s changed or not performing as it was and address those as you get to them.
You never did answer if you are checking the oil window with the bike level and not on the side stand? If it’s full on the stand you are still a decent amount over filled
After hearing what you guys have said im definitely going to get it serviced just to make sure everything is working as it should. I know the guy I bought it off was top notch at looking after his motorcycles and fixing them, but with this oil issue god knows what damage (if any) has been caused. Hopefully the mechanic won’t mind sharing some knowledge about the bike so I can stay on top of everything in the future. And yes the bike was upright when I refilled it not on the side stand so im assuming the oil is fine buddy. Can I ask what should I order for the bike before taking it to the garage? Air filter, spark plugs anything else? I’d rather get them before I get it serviced it’s just a matter of them changing them for me and not having to wait for them to get the parts ordered which would take even longer. I can’t thank you enough for this man i appreciate it so much!
You can download the service manual on this site to get an idea if radiator cap location and what needs pulled to access it. If anything. Sorry I just can’t remember I haven’t worked on this year in a while.
May want to throw brake pads on that list...if you dont need them now you will in the future. Oil filter is another one. Thats all I can think you would need to have ordered. Everything else the shop should have on hand.
Be careful on the ordering. Lots of shops. Me included really hate that. It’s hard to stand by your work when using parts you arnt familiar with or recommend and chances are you want save anything . With that said 99% of everything. Plugs, oil, oil filter. That’s stuff every shop keeps in stock. You could ask the old owner what oil he has been using and maybe just a stick with that I typically like running whatever oil an engine has always ran or whatever quality brand the shop uses will be fine. Now the air filter. That’s something you could research see what you want. I’d honestly stick with oem if you arnt trying to squeeze every ounce of power you can. Oem is going to filter better than a strictly race filter. Some guys love K&n I want use them anymore. I did about 3 days riding at the beach with one and had sand by pass it and the other bike we took had a bcm race filter and it stopped 100% of the sand. So idk. That just scared me away from K&n.
Brake pads. I’d also stick with street or oem. Race pads sound like an upgrade but it’s hard to ride hard enough on public street to get them heated enough to work as well as they should. And they don’t come with much pad life so I’d avoid that. Spark plugs id run ngk cr9e and that’s plugs any motorcycle shop will have on the shelf.
When you change the oil the proper procedure to check is run the engine for a bit or get it warm then turn off of for like 5 minutes and check the oil level with the bike vertical. I usually would do that and then put it on the rear stand and check to see how much different it was - usually very little. If you come back a day later and look at the sight glass it will appear over full. I never worried about that just check it a few minutes after running it and see where it is and then don't worry. I think the difference being if you let it sit overnight oil that is normally on the clutch plates will seep down and make the oil level higher.
Having the shop manual which you can find on this site. Using youtube and the help from the more experienced forum members will get you through this easy routine maintenance.
I basically replaced every bearing (Steering stem wheeles and swingarm), rebuilt my calipers did a valve adjustment and countless other things which I had never done before with the above mentioned help.
Hey guys and gals I am doing a whole bunch of stuff to my 2013 636. List is at the bottom of this post. I bought it used and I want to give it a thorough advanced tune up/maintenance before next year. Along with all the fluid flushes I was going to do the following: Clean fuel pump Clean fuel...
www.zx6r.com
Thats a link to everything I have done if your interested. I had zero mechanical skills before starting this project. The only maintence I did was wash my bike, chain and lube it.
Now I am pretty confident in taking on any maintenance, upgrade, repair or trouble shooting besides electrical lol that is next level but maybe if RJ or Scummy let me face time them I might be able to get that done too.
I’ve been watching videos and gathering as much information as I can online and it definitely seems like a lot to ask, not just fitting the parts but actually getting them as quick as I need them. Knowing my luck I’d probably end up making the whole situation worse so I think my best bet is to ring a few mechanics/garages and see if they can help me before I even attempt it. Still can’t believe how many people are sharing their knowledge to try and help me you guys are legends
I’ve been ringing garages all morning and I’ve finally managed to squeeze it in on Thursday (thank fuck lol) I’ve ordered myself air and oil filter along with 4 spark plugs they should be here tomorrow or Wednesday so it’s all falling into place for me. I’ll report back to let you know how it goes but fingers crossed she’ll be sweet.Thank you all so much! my mind can finally be at rest knowing I won’t be doing anymore damage to the bike
I understand and I’d be absolutely fine with that buddy but a lot of the garages near me usually have to order the parts in (depending what was needed) hence the reason I took matters into my own hands, but the main reason for that was if the garages were to busy like they normally are I could at least do it myself. But after two hours of phone calls someone managed to squeeze me in and he seemed quite happy that it was just the labour needed. If I had more time and wasn’t in my current situation I would let the garage advise me on what parts to get and let them order/fit them but with me needing the bike for work by Friday I had to order them asap so that leaves me more time to install them myself if that makes sense. Thank you
Got the bike back today and it seems like I was a little worried for nothing, it definitely needed the service because the air/oil filter and spark plugs hadn’t been changed for years but there wasn’t much oil sucked up into the air box like i originally thought, the thing that surprised me the most was the price he charged me it was astronomical but the main thing is she’s back running sweet! Thank you for the help gents I really do appreciate you sharing your knowledge with me. For anyone in the same position the best bet is obviously taking it to a garage but they can also take advantage so if you have more confidence and better weather conditions I’d recommend doing it yourself as the parts aren’t cheap and the labour certainly isn’t depending on who you go to. I really hope this forum helps someone in the future because I had no luck finding information on it, and most importantly I hope you learn from my mistakes I know I certainly have. Safe riding everyone!
Awesome. And you prob ended up burning off the majority of the oil. But glad you’re sorted and good to go. A few good reliable fun rides and maybe your wallet will forget about it.
The fees at any service provider are what got me into working on my vehicles. I learned from my father and took it up as a hobby because I couldn’t afford not doing so.
You play, you pay. I play more, by doing my own work.
With the prices of everything rising I’m definitely gonna start doing the same thing myself as long as this horrible weather allows me to anyway lol one last thing gents, when I first had the bike it would start as soon as I pressed the electric start in but now I find myself having to give a little bit of throttle just to get her fired up. I assumed it was because of the oil situation at the time but now everything’s been sorted and the issue is still there I was just wondering what it could be? When she’s warmed up to operating temp it’s fine but on a cold morning I need to pull the throttle back a touch for her to start up I’m assuming this isn’t normal
Starting any engine on a cold day takes more fuel than on a warm day.... when the oil is thick, and the engine tolerances are more open than they will be when at operating temperature it takes more fuel to get it to run well enough to get warmed up. You may need to apply the enricher on your bike.
FI bikes take care of this for you, as do FI cars. They have a specific portion of their programming that applies only when the engine temperature is below the acceptable range. That 'open loop' programming automatically increases the ratio of fuel to air to make it easier to keep the engine running. Once the temperature builds enough, the 3D mapping takes over, and all of the various things that are monitored have an effect on what amount of fuel is applied under specific conditions. That's what all of the environmental laws have driven us to. Just enough gas so it burns off as completely as possible.
My 1971 Triumph Tiger had a button on the side of the carburetor, which you had to use to 'tickle' the carb before trying to start it on a cold day. I think it just sank the float in the bowl, so you flooded the intake with gas, which increased what would be sucked in when you tried to start it. The rule of thumb was hold that button until you saw fuel leak out on top of the engine case....
A traditional 'choke' used a plate in the throat of the carbs that would change the velocity of the air going over the needle that metered the fuel.... the higher speed airflow dropped the pressure, which caused more fuel to come out. We still have those 'butterfly' plates in use to this day, for slightly different reasons.
Traditional carbs had a fairly limited range of operating conditions, all based on how fast the air moved through the throat of the carb. That made them fairly sloppy with the fuel metering at idle, and that got the EPA in a huff.
Constant Velocity carburetors came about as a result. Instead of letting the airflow randomly pull fuel out of the jet, the CV setup uses a tapered needle that is pulled out of the jet more, with more airflow. The taper determines how much fuel gets into the airflow.... the volume of air, rather than the velocity then controls the flow of fuel. The 'constant' part of their name relates to the fact that the venturi through the body of the carb is meant to always have airflow at the same speed. The size of the opening adjusts to maintain that velocity.
With CV cabs, a traditional choke doesn't work. Now, the metering has to change and that takes another metering circuit in the body of the carb to allow that increase when the engine needs more fuel during start up.
Just wondering if this is something that should of been taken care of or at least flagged up during a service? My initial thought was perhaps the carbs need cleaning but as you are probably aware i have no idea. This is only my 3rd 600 with my first being an 08 cbr 600rr, then and 05 r6 and never had any issues with any of them until I got this zxr6. The bike definitely wasn’t having these issues when I first bought it so I’m wondering if it’s something I’ve caused or if they’ve masked the issues just to sell it
Btw thank you for the help I just don’t understand what half of it means sorry, I have very basic knowledge and I definitely need to start learning not just riding
Oh it’s a 01. I was confusing this with another thread with the guys 23. But yea like riverz said the enrichment is all that should be needed if it’s setup properly
And fyi. For non mechanic people an enrichment knob and choke is the same thing lol.
Thanks for clarifying that lol I just went and tried starting the bike and it just doesn’t want to start, but with a little throttle (which I know is bad) helps the bike start up so what sort of indication does that give? When I first bought the bike I had no issues. I put in a new battery and as you know i just got it back from the garage yesterday after having almost a full service. Shouldn’t the start up be something they would of picked up on and should of mentioned?
Yeah that’s exactly what I thought man but not a single thing was mentioned, but the guy I was speaking to seemed like he had a lot of knowledge when it comes to ninjas in general. Im not to sure I’ll go and check but I’m assuming it’s lower than what it’s suppose to be
There should be a lever on one of control pods, that enriches the mix manually when the engine is cold. If that is stuck 'on' then your bike will always run rich even after it warms up. If it's clogged up, it will be hard to start when cold, even if you try and use the enricher.
Carbs gum up on the slow, low volume circuits, first.
Bikes also become more difficult to start when the valves are out of adjustment, or you have any number of possible vacuum leaks.
