1 - 2 of 2 Posts
Whats up fellas, i have a 16 zx6r stunt bike and whenever im on a wheelie if i get to high rpms it starts to sputter / bog out and becomes very weak at top end. Anyone have this problem before? Swapped out the fuel pump already.
It's probably sucking oil into the airbox via the crank case breather tube. You would need to detach the crank case breather tube from the airbox, plug the port on the airbox, and then attach the crank case breather tube directly to the PAIR valve.
1 - 2 of 2 Posts
