1 - 7 of 7 Posts
My boss was talking about this device(maybe the whole throttle) that changes the amount of twist needed for full throttle. I was wondering if anyone had heard of this device?
Kawasaki has a kit for it or you can be cheap, open up your throttle and put something like a plastic zip tie under the throttle wire wrapped around your grip.
However, before you do this mod remember the risks that you are doing.
You have less margin of error with your throttle, so it will be more sensitive which can be problematic in the wet, coming out of a corner, ect... if your not careful. I suggest you being a very experienced rider before you do this.
Indeed. The Zip Tie mod works pretty well but you can buy quick turn throttles. They cost a fortune though!
I'd leave quick action throttles for the track personally. I like the greater control of the standard kwak fit thanks for the road.
1 - 7 of 7 Posts
