No, the shop hasn’t. They are still 2-3 weeks away from even touching it because everyone is trying to get their bikes running for summer. The only thing that sounds different is when I rev high and let the RPM fall back to idle there is a some subtle popping right before it’s back down to idle revs which makes me think that my valve seats may need worked on and is causing my valves to not properly seat and causing small ignitions in the exhaust system. But I honestly don’t know. That’s just a theory because every other thing I can think of has been replaced. I have no FI lights either so that doesn’t help at all
Reading back over your posts;
(Forgive me if I missed this in your replies)
Fuel/Gas Cap ? Did you try and ride the bike with the cap open ?
You say that the fuel pump was replaced , was that with a drop in replacement for the pump itself or the whole pump assembly system?
Those rubber O-rings in the fuel pump assembly could be seated incorrectly or the fuel pressure regulator might not be out of position/direction
Your bike has a custom exhaust system.. has the clean air mod been done ? Is the bypass vent that the crank case uses closed up ?
The revs staying up for a long time could be an indication of the air system being out of correct settings..
When the bike starts up it measures air from the sensor mounted to the air cleaner element housing (as the airbox is called in the manual)
If that reading is out of range the ecu can put the bike into one of the two restricted modes..
BUT then you would be getting a fault code if I'm not mistaken?
