Hello All,
Hoping you could help me figure out why my 08 ZX6R will not start after a year of sitting. I was dumb and left a little fuel in it after I started it last (June 2018) and my fuel pump seized up completely. I have since replaced the fuel pump with a 100L/min pump per the service manual but the bike will not start on its own. I can start it by spraying starter fluid into the intake, but it seems as if the injectors will not spray. I checked with a test light at all 4 primary injectors while cranking the engine and I am getting power to the injectors. I have not verified fuel pressure as I do not have that tool. Any thoughts?
I have tried cleaning out the injectors and replacing the primary rail with a used fuel rail, but still no luck.
