Turn up the idle speed
check the oil level
change the oil
check the oil level
change the oil
Thanks! Will change oil tomorrow, but how do you turn up the idle? Sorry for the question but this is my first sport bike.Turn up the idle speed
check the oil level
change the oil
Great.Thanks a lot!Small Black knob on a cable hangs down on the left side of the bike, under the frame rail should be clipped to the coolant line
idle speed should be about 1300rpm, or just slightly higher if need be
