07 zx6r crank no fire
328 Views 22 Replies 7 Participants Last post by  Scorpi0
As said have 07 zx6r the bike wouldn't go over 50mph so did research and e1 pointed to fuel pump or secondary injectors so went ahead got both installed made sure pump was pumping gas not the pressure but had prime an gas flow then bike wouldn't fire. It fire with startor fluid and die when quit spraying so back to blogs an got crankshaft sensor still no help then got new battery spark plugs an starter relay still nothing so now I have stator rectifier coming this week plus got new power commander thinking maybe would fix an told wouldn't so didn't install but over $1000 an nothing and can't find no one around Elizabeth pa that work on fuel injected bikes so I need help an came across others on here with exact same issues symptoms and will end with up and running with no resolution on how they fixed it plus got brand new plastics I can't put on cause tear apart then back with nothing and siked out what power commander gonna do plus finally nice out and got worst bike fever ever and killing me please any advice help be much appreciated and depending on help would cash app couple dollars for few drinks or whatever. Thanks
21 - 23 of 23 Posts
Hey how do i pull codes on bike? 07 zx6r, I tried hold mode for five seconds an tried hooking lead to yellow wire near negative battery terminal! And I'm not getting any changes in blinking sequence. Maybe this will help lead in direction of firing bike up. Thanks
I can’t remember the 07. But make sure the info window is toggled to the actual odometer setting before you start the sequence. I know for sure the new gens if you are on trip or anything else it want pop up the code. So maybe check that. Are you sure it’s thrown a code? If there isn’t a code it want show anything either.
21 - 23 of 23 Posts
