1 - 11 of 11 Posts
Hello new to the forum. I'm in the process to replace the forks oil rings and I noticed one of the forks have this type of damage
Do you guys think this is enough damage to compromise the hold fork?
105556
105557
105558
Yup as Otto says, that is not good, needs replacing.
Sent from my ELE-L29 using Tapatalk
Ok I order a replacement outshell tube
Another question does any know if this can be fix? There is a little discoloration
105564
105565
Looks like that could be from someone servicing the fork. Most of the time, people will use a small propane torch to heat up the area around the fork seal to make it come out easier. I’m sure it would polish out.
I got these forks for a project I'm working on it, there was supposed to just need a oil seal replacement but after taking them a part I notice the left side cylinder is bent
105590
Now the a have a few questions
  • does is work to get a new cylinder? $300 at partzilla
  • does anyone know if this are from a 05-06 zx636 or an 06 zx6rr? I got a 05-06 fork from a zx6r but the cylinder is a little shorter and wider that what is inside
Picture is the right side (top)
105591
Does anyone know what color paint is this?
Kawiugly???
on a more serious note......... why pay $300 for an oem new cartridge? aren't there a shit ton of complete sets of forks for that kind of money, then you have a spare one?????????
or just move up to aftermarket cartridges for triple the money and have the most awesome front suspension you could imagine
Discussion Starter #11
Kawiugly???
I know, I got a used set with nice cartridge from ebay. I will rebuild the the set with DLC color tube.
I'm acking the question due that I will be cutting the bracket where the front fender goes and I will like to match the hole piece once I'm done
1 - 11 of 11 Posts
