1 - 11 of 11 Posts
Ok i'm at a loss on where to buy a fan switch/water temp sensor I can find them on ebay and other sites but not for the 05/06 . Can someone let me know what other years have the same sensor .
Do you know if your relay is bad or is it your temperature sensor?
Does the fan not come on at the right temp/not at all?
ok I believe I found the part number but correct me if I'm wrong 21176-1120 that's the fan/water temp switch correct ?
213-215 is use to come on at now not to almost 230 f and it starts to overheat sometimes flashing on hi I checked the water pump impellars are intact so I changed the thermostat but need a new gasket FML lol the next I can only think of is the fan switch/water temp switch in the head
It sounds like your temp switch/sensor. Mine kicks on at about 210ish and cuts off about 207. Running at or above 230 could lead to problems. Check partzilla or Kawasaki Parts House (outragous shipping though).
Discussion Starter #9
I had ordered one off of eBay today so I'm keeping my fingers crossed that it's my problem and yeah I won't run it past 225 if I can help it but I am dying to ride this sucks .
Yeah somethings not right. My fan kicks on at 214.
1 - 11 of 11 Posts
