Hey guys,
so as the Tittle states, i would like to start learning how to do to sit down clutch wheelies
I've tried a couple of times and got the front wheel off the ground by half a wheel
Any helpful tips? first gear? second?
My biggest worry is 12 o clocking... how long do I need to pull the clutch in for? increase of throttle when the clutch is disengaged? RPM's?
obviously i cover my rear break.
any help would be appreciated :)
thanks again!
Dane
Ya he gives good advice. The key is to pop the clutch while you are throttling up. Don't hold the throttle at a certain RPM and try to pop it up. 1st gear clutch ups are the best place to start. Just practice your timing with throttle and clutch and experiment with different RPM's
look at other threads (theres a ton on wheelies) and practice
