1 - 2 of 2 Posts
When removing the Throttle Body Secondary Butterfly Valves, I noticed that one of the two hex bolts that clamp the assembly tight over the valves was stripped out, and will not come out with a traditional hex or allan head. I managed to push that side back in pretty well and tighten the other bolt just fine, but it's really bothering me thinking about that bolt. Any ideas on how I could possibly remove it without pulling the whole engine?
If you're able to loosen the others and get the airbox off, you can grab it with some pliers to get it out or use an easy out. I know for a fact that they sell that exact same bolt at Ace Hardware.
1 - 2 of 2 Posts
