Howdy guys! Im having an issue with the electrical on my 05. I was riding a while back, and came to a light. It started to die out on me (1st gear, clutch in at a stop) and after a quick throttle blip to try and keep it alive it cut completely. I had dash lights still at the time. Had it towed home, and let it sit over night. Bike started just fine, rode for about a mile and a half, then did the same thing. On recommendation if some techs I know, I replaced the Stator, Regulator, and Rectifier. Made sure the battery was charged, turned the key, and it lit up for a minute, then my backlighting and indicators on the dash flickered (N, Fi, and Oil, standard lights that come on with just electrical power). Along with this was a ticking noise that sounded like it was coming from the fuel injectors/under the tank. Drained the battery in less than 5 minutes. Any ideas?
Thanks in advance,
Squiddy
1/21/23 UPDATE
Got a new Lithium battery charged and in the bike. Started right up and ran fine for about 20 minutes, then died on me again. As of now Im thinking the issue is not that the stator/reg/rec are not charging as they are new, but that somewhere along the line something is preventing them from charging (yeah obvious I know). Will be going through the electrical system to see what I can find. Any ideas are appreciated.
Thanks again guys,
Squiddy
Thanks in advance,
Squiddy
1/21/23 UPDATE
Thanks again guys,
Squiddy
