Hey everyone, first thread i’ve made, in desperate need of help, my f1 light on my 636 only comes on when it’s running, takes a second to get it to start, I have to adjust the idle screw just to get it to idle okay, I did some digging and found a wire had broken off of the base of my map sensor, so I tried stripping as much as I could from the plug and stripped some wire back to get fresh wire and shoved it up against the broken yet exposed wire to see if that could be my actual problem, sounds stupid for me to ask this question but I’m not sure if I’m right i know wiring but not 1,000% so I would think atleast having some contact it would work
Some contact on the wire should be fine for testing. Its just a sensor wire…nothing that has a bunch of amps flowing thru it.
What code is the bike throwing? Theres a wire u can connect to ground and the FI light will flash a number of times, indicating the code. If you dont know how to do that, let us know and we can show u. Theres a thread dedicated to doing that task.
Will it keep running fine after it warms up? What if u keep the throttle open manually after it starts? Do u have a power commander or some other kind of aftermarket fuel mapping unit on the bike?
The f1 light only comes on when the bike is running, it doesn’t stay on when the ignition is on, I depinned the connector and reworked the connector itself, still same problem
You need to pull the codes, don't play the guessing game. You will want to go into dealer mode 2 to pull up a history of all FI codes thrown, if not currently present. It will go in order from oldest to newest, so the last set of blinking lights is the current sensor issue. If you have too many codes and you're getting confused, you can wipe it clean, ride the bike and the next time the FI light pops up do the same diagnosis, and it should show all relevant issues.
It's pretty straight forward to pull the codes. See below link, give it a shot and let us know if you have issues after that.
This How To is performed on a 2003 Kawasaki ZX-6R and will be the same for any of Kawasaki's ZX models with fuel injection; other Kawasaki Fuel Injected bikes have similar or identical methods to pull the FI codes, so hopefully this will help. There are two Self Diagnostic modes you can enter...
www.zx6r.com
Related Threads
Kawasaki Ninja ZX-6R Forum
1.2M posts
47.1K members
Since 2006
