1 - 5 of 5 Posts
Hey guys I have an 04 636 . It Sat for about 1year rear set locked up. Fixed that problem. It felt like it was frozen. I fixed it . Look at the video this is the new problem never moved that shaft arm. (I did take the clutch out and but it back it . Everything is fine in there. Push rod is good everything is set in there)
04 zx636 weird clutch/trans issue - YouTube
What can be causing this?
Anyone have a pic of their 636 shaft arm so I can get an idea where mine needs to be if it needs adjustment. Thanks
Super Moderator
... <shot_in_dark>
Are you rolling forward enough to be able to engage second?
</shot_in_dark>
That isn't the case here I've rolled it all the way down the driveway . If bike was on it will go into every gear up. But then I'll have to adjust the shift bar to down shift
1 - 5 of 5 Posts
