The Issue: Ran hard for 80 miles in the morning. Stopped to take a break, got back up to leave, bike surges at ~8 k rpm. Bike revs through until it hits 8000 rpm then it feels like fuel cuts. If I hold the throttle on, it will buck, going on and off every second or so. No FI codes.
So Far: I have changed spark plugs, checked coils for impedance and spark, checked air filter. Took the fuel pump out, cleaned out the screen. Did the inspection on the pump per the manual: fuel pressure and flow rate were both in spec.
I feel like I've done the easy stuff so far. Anyone have any other things to check before I go insane? I do have an ebay fuel pump on the way that I will try in a few days.
Thanks
Thanks
