It is never "just the connector"........... but go ahead and replace the connector......... in a few days or a few weeks you will be buying the stator and likely reg/rectifier anyways..........thing is im on a budget and the stator and rectifier have been running fine with the burnt connectyor sinse i got it so i think its just the conector.
I'm volt reading evrything tomorrow if the stator and rectifier put out the voltage you specified does that mean in working as intended I assume so but I need to ask?You could forgo any connector and simply hard solder and shrink wrap each wire to each wire..... but yes, any of the three yellows from the stator can go to any of the three yellows coming out of the reg/rect (you are going to end up throwing all these components away sooner or later anyways)
and yes the stator puts out A/C current and the job of the reg/rect is to convert it to DC volts and shove a bunch of that power to ground when not needed
Did you???
put you voltmeter on AC volts and test the actual AC output of each of those yellow wires coming out of the stator??? rev it up to atleast 4000 to get a more accurate reading, should surely be over 40v, and all 3 should be essentially the same output (within 1 or 2 volts)
I am not sure how your jump box is going to work at being connected to battery to power electrics while you try and drive it home?????? Sure it may well start the bike, but as soon as you unhook the bike will likely die if it is to the point of needing that jump box to start it.....
How do I test the rectifier from the battery since that's what I need to test is the voltage being taken after the rectifier does its thing and that's only after I test the stator. And is how I test the stator positive at muntimeter to wire, negative to a ground?The ACV reading is only out of the stator 9and if this is bad then the reg/rect cannot be easily tested (40ACV-52ACV from each individual wire/phase when bike is running above 4000rpms)
The DCV reading out of the reg/rect is measured at the battery teminals with bike running (13.9-14.5DCV when bike is running above 4000rpms)
Service manula does have a test for the reg/rect with it out of the motorcycle (bench test) but.......... I have had brand new ones test bad and bad ones test good, so I rely on...........How do I test the rectifier from the battery since that's what I need to test is the voltage being taken after the rectifier does its thing and that's only after I test the stator. And is how I test the stator positive at muntimeter to wire, negative to a ground?
i checked over the rest of the harness because the bike has been in peices pretty much and besides the eletrical wrap coming undone thats the only conection thats like horrible all others have been insp;ected tho the greese you tal about wasnt applied.To follow up on the advice above...... Do you really think those two plugs are the only ones that are degraded?
