is it doing it when you're coming off the throttle? Maybe consider some block off plates. Due to it being just a slip on, you shouldn't really need a fuel management system, but it wouldn't hurt.
Bazzaz and Power Commander are the 2 giants in the industry when it comes to fuel management systems. There are other options out there as well but you probably wouldn't know about them unless you did extensive research.Hi SCMil, thanks for the reply. I believe it is happening when I come of the throttle and then going back on. I'll check out block off plates. I've heard a lot about Bazzaz. Could you help mexplain understand the pros and cons?
http://zx6r.com/zx6r/34387-official-bazzazz-q-thread.htmlHi SCMil, thanks for the reply. I believe it is happening when I come of the throttle and then going back on. I'll check out block off plates. I've heard a lot about Bazzaz. Could you help mexplain understand the pros and cons?
I recommend IMMEDIATELY posting video of the supposed flame spitting phenomenon or the internets will never acknowledge that it has actually occurred and will, therefore, never impart to you the answer you seek :bitchslap:the exhaust is spitting out flames alot!
what would you recommend and why?
I would have to commune with them a little more to be sure, but from past experience, I'd guess that the internets would even be willing to comply with your requests in exchange for some crappy cell phone footage shot from a nearby car at nightGotta get that GoPro! Nitrusreigns
