Hello,
I started again to do trackdays with my zx6r 03-04. I am on the slowest group but event on my slow pace I get so much tire wear
I didn't have any luck with rebuilding original shock (it was hard) and event with 09-12 shock. I also tired to rebuild it. As you will see in the picture it looks that I don't have enough rebound damping. I ride on Metzeler Sportec M7 RR tyres. The track is left corners dominant so the main wear is on left tyre side.
Anyway since I am slow rider and I don't see any reason to invest into new aftermarket shock I was thinking maybe I could mount zx6r shock from year 2013 ?
I made some research on Ohlin's page and it looks that 03-04 has:
Length: 340
Rate N/mm:100
Stroke: 74
zx6r 2013-2021 has:
Length: 341 +2/-4
Stroke: 64
no specs about spring rate
So here is the only difference in 10mm on shock stroke which I think should be fine.
I would like to find any advice from your experience before I will make any order online. I am located in Europe so there are much less to chose from. In USA these OEM shocks sell very cheap. I don't know why in Europe OEM shocks are so expensive.
Length: 340
Rate N/mm:100
Stroke: 74
zx6r 2013-2021 has:
Length: 341 +2/-4
Stroke: 64
