1 - 16 of 16 Posts
Alrighty Guys and Gals I need some help. I put a new wiring harness on the bike I have compression but the plugs wont fire. I pulled them out and tested them. The plugs look healthy, But Im not getting any spark in them. Is there a senor that goes bad that would prevent me from getting spark. I also checked the fuses but none of the relays. I was hoping someone on here knew of a common problem or at least a place for me to start. All help will greatly be appreciated, Thanks
Are you getting spark from the coils?
Oh boy lol i can prolly be of assistance here i have been through it too brotha.
which wiring harness? main one, coil one, or pickup coil one? was it working before that? and have you already considered the bluntenly obvious?
I replaced the main Harness... I did consider it was the battery cause i pulled it out of the CBR but it runs the CBR... and its brand new... how do I test spark from the coil?
The bike did not run when i got my hands on it due to sitting and a large section missing from the main harness... I got the Main Harness from a dude on Ebay and from what i can test that isnt the problem...
What does it do when you hit the start button? I normaly out a screw driver or plug in it and sit it on a metal part of the bike and see if there is a spark and what color it is.. I had this problem in my car and turned out to be a broken wire on the ignition side. It would have a weak spark but not e bought to start it.. Have you tried areostart?
Discussion Starter #9 (Edited)
I pulled the plugs and grounded it but there wasn't a spark... even talked my buddy into holdi lol should have give him a poke but we didn't get anything... what is aerostart
Have you got all the ground wires hooked up? Does everything work on the bike?
Discussion Starter #11
Yeah everything is grounded... and everything is hooked up... it turns over my gages work... but no sparky spark
Premium Member
Okay, I'll give you a few things to check.
1. When you turn the key to the on position, do you head the fuel pump priming? It should hum for around 5 seconds, this is a different sound then the subthrottle valve clicking and beeping. If it doesn't prime, then there's a good chance your vehicle down sensor is triggering and broken. The FI light should be on if this is bad though, so if the pump doesn't prime and the light is off, then your gauge is bad, or the ECU is bad.
2. Pull off the plug for the radiator fan switch, use some insulated wire and connect the two leads inside the plug. Your radiator fan should come on, if it doesn't, your sub-harness either isn't connected or is bad.
3. Make sure you have the correct plugs, if you do, check the primary and secondary windings on the coils, checking 1 or 2 is sufficient, there's practically no chance they're all bad, but you never know, these bikes aren't getting any younger.
That's the quick stuff to check, if everyone is within spec there, lets move on to the interlock system:
Get your multimeter out (should already be out for windings) and head to the junction box. Set it to 25V DC and connect the (+) lead to the G/BK lead in the junction box and the (-) lead to your frame ground. With the transmission in first, the clutch lever released, and the sidestand down, turn the ignition to on, and you should get 4volts or more. If it's under 4 volts, check the sidestand switch, starter lookout switch, and junction box. If they're fine, get a new ECU. If the voltage is 4volts or more, hit the starter button, if the starter turns, the ECU is bad. If it doesn't turn, then its fine, and proceed to check the rest of the starter system circuit.
Before doing all that noise, are you even getting power to the coils? Stick your multimeter on the wires up to the coils. If you don't have the proper adapters then just cut into the wire on one of them and leave the coil installed but no plug. The red is your positive wire, and the black is the negative, put the multimeter at x250V DC range and crank the engine, you should be getting 100volts or more. If you aren't check the crankshaft sensor.
So, for the crankshaft sensor...back to our friend the multimeter. For the first resistance measurement check it at the sensors lead connector, the connectors are near the rear brake fluid reservoir. Measure the resistance, it should be at 460-470 ohms. If it's higher then the coil has an open lead and replace it, if it's less then there is a short in the coil, and replace it. And on the connector, it's the two leads on the bottom and right, if you look at it with the clip on top. Now change your meter to the highest setting, individually connect each lead to the frame ground, if it's anything but infinity, it's shorted, replace it.
If that's fine, then check the voltage. Turn the meter to the 10volt DC range, connect the negative from the adaptor to the bottom middle of the connector, it should be black/yellow. Then connect the positive of the adaptor to the bottom right, it should be solid black. Then pull in your clutch and hit the starter for about 5 seconds with the transmission in neutral, it should be 2.0volts or more. If it's not, take a guess at what to do, crank sensor first, then the ECU.
If those are fine, you could be super thorough and check the continuity of the wire. The black wire out of the sensor ends up at the 24th node/terminal/plug/etc. of the ECU, and the yellow/black wire ends up at terminal 11.
I'm tired of typing, do all this and reply here and I'll find think of some more crap to diagnose.
Discussion Starter #14
Dude I think this nails it... I was so frustrated the bike wouldnt fire I didn't realize the fuel pump wasn't priming... also where is this sensor supposed to be located, I have been rebuilding the bike mostly the wiring cause it was all bad... When I google imaged the sensor it was definitely something I haven't seen on my bike so I'm guessing its missing altogether which is why she won't run...
Premium Member
The vehicle-down or "tip" sensor is located just in front of the gas tank's rear mount and about an inch below it. It's attached by two bolts, to the frame itself.
If you find that you do have one, and are still having the problem, a quick diagnoses would be to grab a semi-old AA battery (1.5V) and check the current in it, if it's between .4-1.4 then you can use it. Then connect the battery's ground side to a ground, and the positive side to the middle terminal in the connector for the tip sensor. This should dupe the ECU into thinking it has a good signal from the tip sensor and you'll get a fuel pump prime and spark.
If you don't have a tip sensor but want this thing on the road or just want to bypass this sensor for a little bit while you finish getting everything else together, you can run up to....radioshack maybe, or just a hobby shop and get yourself a resistor that will take 12.5V DC and let .4 to 1.4V through it and hook that up to the ECU main relay's output on the connector and then the tip sensors output terminal on the same connector. The size resistor you'd need is outside my knowledge base though.
edit: Let me know what's up, I'm not 100% sure, but I might have a spare tip sensor in my garage, I'll check tonight when I get there.
Premium Member
Hey Apollo, just got back home and checked my garage and I do have an extra tip sensor here. Let me know if you need it and I'll ship it out to you for free whenever. But after sunday or so I can actually test it on my bike to make sure it's good before I send it.
1 - 16 of 16 Posts
