1 - 3 of 3 Posts
Can anyone help me out with what the specs should be for the fuel pump on a 2001 ZX6R? I have heard some numbers about the pressure cutoff, but haven't seen anything about the flow rate or anything. Does anybody have some detailed specs about the stock fuel pumps? Thanks
Super Moderator
I'm sure the service manual would have those kind of specs. You can dowload the full PDF version here.
They are just a shuttle pump similar to a diesel lift pump. They don't flow much at all because anything over about 2-3psi would
cause the carbs to flood out. The pump is there strictly to boost fuel when higher demands require.
1 - 3 of 3 Posts
