Voltage drop after start engine - ZX6R Forum
  • 1 Post By RJ2112
  • 1 Post By PowerGroove
  • 1 Post By riverszzr
post #1 of 8 Old 02-02-2019, 04:15 PM Thread Starter
Hello guys, Im riding a kawasaki zx6r 09 model. It would be great if all the ninja could help me n my poor baby. Recently i had this problem. Before i start the engine the voltage shows 12.2v and after start it shows 13.8v which i think it is normal but after a long ride i notice my voltage start to drop to 12.9 after i close my throttle.When stopping voltage shows 12.4v - 12.6v. When moving and rpm start to increase the voltage also start to increse. After i notice again the voltage start to drop more until it reach 11.9v when stopping. And now before start engine the voltage shows 12.2v thn after engine is start voltage shows 11.9v. Is it battery problem or the charging system?
Shaikh Zafer is offline
post #2 of 8 Old 02-02-2019, 04:39 PM
Sounds like the alternator is not putting out as much power as it should..... hard to say for sure, without knowing more about how old the battery is. If the battery is more than 5 years old, it is likely causing a lot of strain on the charging system, because it will not hold as much energy as it did when new.
If you have additional electronics on the bike, that will also cause the charging system to work harder than it is meant to.
You may have dirty or corroded electrical connections --those create resistance, which takes more power to overcome..... straining the charging system.
The diagnostics in the shop manual are pretty comprehensive, for troubleshooting the charging system.
The bike should be able to run, just off the battery for a time...... that means you can start the bike with the alternator disconnected from the regulator/rectifier, and measure the AC Volts coming out of it. Any pair of the three wires from the alternator, should have at LEAST 57 VAC (~ symbol) between them. 75 VAC between all three phases, is a really healthy '09 alternator. You should see maximum AC Voltage, with more than 3K RPM.
If you don't have even values between all three phases, odds are pretty good the alternator is damaged.
If that's okay, you have to move on to the DC side of things, which you have mostly already looked at. This is why I suspect an old battery, first. Pull it out and get it load tested. Replace if need be.
post #3 of 8 Old 02-06-2019, 01:30 AM
Gawernator's Avatar
If the battery is more than 4 years old it almost certainly needs replacing.
http://www.gawerracing.com
Gawernator is offline
post #4 of 8 Old 02-06-2019, 07:22 PM
I skimmed over but didn't read every word in this thread. ... but I'd also give the nearest dealer a call and have them run the VIN to see if that bike ever had the reg/rec recall.
Yes... Your charging system is not doing its job. Even a shit battery should ready over 12v when the bike is running.
PowerGroove is offline
post #5 of 8 Old 02-28-2019, 07:14 PM
863JOE's Avatar
I second this. My 09 fell under this, thankfully.
If I were a betting man, I'd say your rectifier is the culprit.
2009 ZX6R- M4 slip on, d3 grips, ASV C5 levers, Dunlop Q3's, Roaring Toyz SS brake lines, Vortex -1/+2 sprocket setup with Speedohealer, Bazzaz z-fi tc w/ AFM, K&N race spec filter, vortex rearsets------SOLD------
2015 ZX6R- Matte Gray/Black, M4 street slayer, TST integrated tail light, TST fender elimination, Power 2CT's, that's all for now.
863JOE is offline
post #6 of 8 Old 02-28-2019, 07:45 PM
bad battery IMO
but not enough coherent information to make a diagnosis via the internets
However if you are saying;
while it idles the voltage is low (12.4-12.6v)
while it is not running the voltage is low (11.9-12.2v)
but anytime you have it running and rpms above 4,000 rpms, and you have ~ 13.8ish volts then it most certainly sounds like the battery is the issue not the charging system
but very tough to make sense of your poorly articulated jibberish
post #7 of 8 Old 02-28-2019, 07:46 PM
double post
post #8 of 8 Old 03-01-2019, 03:56 AM
863JOE's Avatar
bad battery IMO
After reading it carefully and spending more time than I should've trying to make sense of it, I retract my statement about the rectifier and vote battery too. The first time I read it, I deciphered it as voltage being sporadic in general.
863JOE is offline
  ZX6R Forum > ZX6R Forum > Ride Reports
'13 ZX6R Engine Light on madmax31 Mechanical and Technical 4 01-05-2019 12:42 PM
drop my bike. Won't able to start Ali6R2006 Mechanical and Technical 5 10-24-2018 05:11 PM
Bike wont start! KYD The ZX6R 7 03-08-2009 07:23 PM
Good engine deal? mityaz The ZX6R 13 12-20-2008 08:39 PM
