Rebuilding a ‘05 636 - Page 5 - ZX6R Forum
 10Likes
post #61 of 77 Old 11-11-2018, 02:25 PM
Originally Posted by Spyvsspy View Post
Also, zx6r.com isnít very active either. Anybody know of a good forum where I might get more interaction when I have ??ís
Honestly this is probably your best place for information.
Also... take into account the time of year. Fewer people out riding means fewer people posting for now. Always picks up when it gets warmer... that doesn't mean everyone has answers for ya though
I'm usually on around 4am to 7am pacific time if that helps
ďWhy do I ride as number 69? Well, itís a number that you can still read when the bike is upside down after a crash." - Nicky Hayden
PowerGroove is offline
post #62 of 77 Old 11-11-2018, 05:39 PM Thread Starter
Spyvsspy's Avatar
Used the battery from my 16 DRZ to test out the condition of the wiring harness. Finally able to see the miles!
PowerGroove likes this.
Spyvsspy is offline
post #63 of 77 Old 11-13-2018, 02:46 PM Thread Starter
Spyvsspy's Avatar
Having trouble removing one of these pins on the connector. Anybody have insight on how to do it? I’ve looked online but the videos I saw didn’t help me take it out. Also if anybody knows where to find the whole connector please let me know
Spyvsspy is offline
post #64 of 77 Old 11-17-2018, 06:19 PM Thread Starter
Spyvsspy's Avatar
Haven’t done much else due to work. Did the POR15 treatment on the tank and it should be fully cured tomorrow night(4 days total). I need to replace this seal on the fuel tank cap...anybody know where to find it? I went to the Kawa dealer and no luck
Spyvsspy is offline
post #65 of 77 Old 11-17-2018, 06:34 PM
Buy a knock off gas cap, transfer the gasket....?
post #66 of 77 Old 11-17-2018, 08:47 PM Thread Starter
Spyvsspy's Avatar
don’t know if it would be the same design. Going to try to source a used gas cap since i found kawa has used the same gas cap on many models
Spyvsspy is offline
post #67 of 77 Old 11-18-2018, 03:16 AM
The hole it fills doesn't change, the physical size of the cap where it meets the tank has to be the same.....
At least that way you know the gasket isn't perished.
If you feel especially daring, you could use your old one for a pattern and make your own.
ZedExMuse likes this.
post #68 of 77 Old 11-18-2018, 06:06 AM
crstaub's Avatar
I Ride: 2006 Ninja ZX6R 636
Partzilla?
crstaub is offline
post #69 of 77 Old 11-18-2018, 07:32 AM Thread Starter
Spyvsspy's Avatar
The gasket is shaped like a cowboy hat. It goes underneath the locking mechanism and thru a metal collar to where I am pointing at with my screw driver
Spyvsspy is offline
post #70 of 77 Old 11-21-2018, 04:37 PM
ZedExMuse's Avatar
It may be pt# 92093-1030? Don't quote me on this. The schematic is quite sparse with its pictographs in this particular image. Partzilla quotes $6.38/$4.19. The lesser price is if you sign up with them - massively worth it. They never spam me. The gas tank cap is $64/$84, thus even if you bought a new cap, signing up with them is well work it.
Here's the Partzilla.com addy:
https://www.partzilla.com/catalog/ka...0-n1/fuel-tank.
Maybe try eBay for a whole gas cap, and then pirate the gasket.
C8H10N4O2
ZedExMuse is offline
post #71 of 77 Old 11-29-2018, 09:53 PM Thread Starter
Spyvsspy's Avatar
I’m going to have to get another gas cap, unfortunately. Havent gotten much farther due to work....fixed the chewed wire and now I have to get into removing the throttle bodies to clean that up
Spyvsspy is offline
post #72 of 77 Old 12-01-2018, 10:52 PM Thread Starter
Spyvsspy's Avatar
Been finding more help on other non 636 related sites than here...reason i stopped posting. Thanks to those that did contribute. Thought this site would’ve been more active for a 636 rebuild
Spyvsspy is offline
post #73 of 77 Old 09-01-2019, 09:40 PM
Itís looking like I will need to get a locksmith to make me a key. In other news, a used oem fuel pump and throttle bodies arrived in the mail. Going to pick up a battery...going with the Everstart walmart for cheap and will need a chain. Any idea what is a good chain for the money? I think itís 108 links, stock
I would recommend an EK MVXZ2 chain: https://amzn.to/2Hl2Jk9
If it isn't already, I would also recommend converting it to a 520 chain and sprockets.
I use Vortex sprockets (make sure you select the correct number of teeth from the front and rear sprockets): https://amzn.to/2ZgD0Q0
Strider is online now
post #74 of 77 Old 09-01-2019, 09:44 PM
The fuel tank formula is fuel proof and it works wonders! Iíve successfully used it before and it works best after removing as much rust as you can.
Or remove ALL of the rust instead with Evapo-Rust: https://amzn.to/2lRDoqb
Removes all of the rust and doesn't damage the good metal. That stuff is amazing!
post #75 of 77 Old 09-01-2019, 09:48 PM
Having trouble removing one of these pins on the connector. Anybody have insight on how to do it? Iíve looked online but the videos I saw didnít help me take it out. Also if anybody knows where to find the whole connector please let me know
You can check these sites for motorcycle connectors:
http://www.cycleterminal.com/motorcycle-connectors.html
http://www.easternbeaver.com/Main/El...onnectors.html
https://www.corsa-technic.com
  ZX6R Forum > Lobby > New Member Introductions
OG 636 models vs 2011+ 636 silthanas The ZX6R 6 08-22-2018 02:45 AM
2009 ZX6R to 636 Swap ZeeEx6Are New Member Introductions 0 06-16-2018 08:44 PM
Bloody Knuckles and Broken Nails: The Art of Rebuilding MistressOfMayhem The Build Thread 67 03-09-2015 12:09 AM
05 636 race plastics on 03 636 motostunter The ZX6R 2 07-12-2009 11:10 AM
