Rebuilding a ‘05 636 - Page 3 - ZX6R Forum
 10Likes
post #31 of 77 Old 11-05-2018, 12:08 AM
I'm presuming you got the title, with the bike?
post #32 of 77 Old 11-05-2018, 04:19 AM Thread Starter
Spyvsspy's Avatar
Yes, I have the title but haven’t switched it to my name yet. Just picked up the bike last night
Spyvsspy is offline
post #33 of 77 Old 11-05-2018, 05:50 AM
Originally Posted by Spyvsspy View Post
Yes, I have the title but havenít switched it to my name yet. Just picked up the bike last night
You can reduce the cost of getting the key cut, if you can provide the lock smith the numbers off the end of the lock barrel. the seat and ignition should be keyed the same, so which ever one is easier to remove, you can get the number from.
alternatively, a Kawasaki dealer should be able to cut you that key; they will almost certainly need the code as well. Kawasaki's computer system may have that number on file -- better to have the number on file.
post #34 of 77 Old 11-05-2018, 10:26 AM
Depending on what a locksmith will charge you.............
You may be better off to simply buy a brand new complete lockset from Kawasaki.......... about $180
ignition, tank, seat locks all included
That fuel tank looks horrendous........... is it rusty inside too? you will need to clean that out well, or you will continue to have issues
I really hope you paid next to nothing for this bike, like.........well under 1k, as that is all it looks like it would be worth considering the state of disrepair and neglect
post #35 of 77 Old 11-05-2018, 11:13 AM Thread Starter
Spyvsspy's Avatar
I got a quote of $35 to $50 if I take the ignition to the locksmith. I can live with that. There is rust in the tank but it’s nothing I can’t take care of. I am going to clean it out, run the electrolysis process, and coat the inside with POR15. I have successfully restored tanks in the past using this procedure and this tank doesn’t look as bad as the others.
I got this bike for next to nothing! Paid $100 to rent a trailer and truck to pick it up. Bought a replacement fuel pump, throttle body setup with injectors, rearsets, and few few other bits. So far I’m in $450 total. My plan is to spend no more than $1000 total
Spyvsspy is offline
post #36 of 77 Old 11-05-2018, 02:07 PM
I got a quote of $35 to $50 if I take the ignition to the locksmith. I can live with that. There is rust in the tank but itís nothing I canít take care of. I am going to clean it out, run the electrolysis process, and coat the inside with POR15. I have successfully restored tanks in the past using this procedure and this tank doesnít look as bad as the others.
I got this bike for next to nothing! Paid $100 to rent a trailer and truck to pick it up. Bought a replacement fuel pump, throttle body setup with injectors, rearsets, and few few other bits. So far Iím in $450 total. My plan is to spend no more than $1000 total
in that case, you got your monies worth......... lol
good luck on the rehab- it sure appears to need plenty
post #37 of 77 Old 11-05-2018, 04:33 PM Thread Starter
Spyvsspy's Avatar
It doesn’t look that bad...I’m not scared of a little work
Spyvsspy is offline
post #38 of 77 Old 11-05-2018, 07:38 PM Thread Starter
Spyvsspy's Avatar
Can anybody point me in the right direction to remove this for the locksmith
Spyvsspy is offline
post #39 of 77 Old 11-05-2018, 09:37 PM
likely easiest to simply remove the top triple clamp with it attached.........
otherwise security screws are installed and you will need to drill them out- which will require top triple removal anyways.......
unplug it from the connector!
post #40 of 77 Old 11-06-2018, 02:00 AM
How tough to get to the seat lock?
post #41 of 77 Old 11-06-2018, 05:58 AM Thread Starter
Spyvsspy's Avatar
is the seat lock the same as the ignition?
Spyvsspy is offline
post #42 of 77 Old 11-06-2018, 07:33 AM
It's supposed to be....... One key to rule them all......
post #43 of 77 Old 11-06-2018, 08:41 AM Thread Starter
Spyvsspy's Avatar
i’ve been reading that the ignition key rules them all. I will just take the top triple key out and have a key made from the ignition. In the mean time, I’ll get the tank cleaned, clean out the rats nest and source a few more bits that the bike will need. It will be slow due to work but I think I’ll end up building a street fighter.
Spyvsspy is offline
post #44 of 77 Old 11-06-2018, 09:37 PM Thread Starter
Spyvsspy's Avatar
Quick update, doing electrolysis on the tank to get rid of the rust. Removed the airbox and found some chewed up wires, they are in the second picture. Any ideas on how to repair? Also removed the top triple tree to get a key made.
Spyvsspy is offline
post #45 of 77 Old 11-06-2018, 09:52 PM Thread Starter
Spyvsspy's Avatar
Also noticed that there are four separate injectors in the airbox. Didn’t know this bike had so many injectors, should I have to clean those out?
Spyvsspy is offline
  ZX6R Forum > Lobby > New Member Introductions
OG 636 models vs 2011+ 636 silthanas The ZX6R 6 08-22-2018 02:45 AM
2009 ZX6R to 636 Swap ZeeEx6Are New Member Introductions 0 06-16-2018 08:44 PM
Bloody Knuckles and Broken Nails: The Art of Rebuilding MistressOfMayhem The Build Thread 67 03-09-2015 12:09 AM
05 636 race plastics on 03 636 motostunter The ZX6R 2 07-12-2009 11:10 AM
