Misting headlight...common problem? - ZX6R Forum
post #1 of 5 Old 09-11-2016, 04:19 AM Thread Starter
Soody's Avatar
I Ride: ZX-6R B1H
So, it seems that my left (as you look head on to the bike) headlight is misting up for some reason? I've got a B1h. It's not major just annoying so any idea of a fix??
Bounce Bounce
Soody is offline
post #2 of 5 Old 09-11-2016, 06:26 AM
laggy311's Avatar
I Ride: Dirty
Get some butyl rubber glue, the spooled kind not the block (get it from the retrofit source). Take headlights out. Bake them in oven at 200° for 10 minutes. Start to gently pry apart, after loosening tabs. Probably have to repeat the heating process to pull fully apart. Be careful that old butyl glue seal doesn't get stringers on your lenses. Clean up old seal/glue. Clean up inside of lights. Make sure all vent tubes are not blocked. Make sure the vent tubes are actually there. Redo the butyl glue in the seal channel. Press all back together. Bake for 5-10. Press together for good. Let cure for an hour.
...we as a species might just be too incompetent to destroy ourselves
laggy311 is offline
post #3 of 5 Old 09-11-2016, 07:42 AM
ZXROM's Avatar
Make sure your bulb is correctly installed, if it's crooked or partially installed, it will let moisture in and cause fogging.
ZXROM is offline
post #4 of 5 Old 09-11-2016, 07:44 AM
Gawernator's Avatar
On a few occasions I've gotten some super light fogging inside the housing, not really noticeable but it was there. That was on a factory bike, less than a year old.
http://www.gawerracing.com
Gawernator is offline
post #5 of 5 Old 09-11-2016, 07:47 AM
laggy311's Avatar
I Ride: Dirty
Vent tubes/outlets. Make sure they're not clogged.
laggy311 is offline
Headlight problem 95 zx6 MacGyverRI Mechanical and Technical 1 05-04-2015 08:27 AM
95'-97' zx6r after oil maintenance PROBLEM pressure davidko Mechanical and Technical 8 05-02-2015 10:54 AM
A Cry for Help - Headlight v's Power Seasider71 Mechanical and Technical 5 10-14-2013 12:27 AM
10 kawasaki zx6r clutch problem Loganvortex Motorcycle Talk 5 06-03-2013 05:23 PM
Gas Venting problem....kream coating? Brichard The ZX6R 13 05-28-2009 09:22 PM
