Question about tires - ZX6R Forum
post #1 of 2 Old 01-02-2014, 04:26 PM Thread Starter
Skitch's Avatar
I Ride: 2012 Daytona 675
Ok so i'm hoping to get a little feed back about tires.
This is not a thread about which tires to pick...more about the life and condition of a tire.
I brought my 636 home with me on 11/25/13, due to the winter I didn't get to ride more than around the block the day I brought it home. As I winterized my bike I started to notice the tires looked - for lack of better term - dry(sorta).
I called my dealer about getting new tabs since February is nearing and I found out the bike hadn't been registered for an entire year prior to when the dealership acquired it. This confirmed my suspicion that the tires were older.
The visual inspection of the tires shows, to the best of my judgement, that the center tread is around 50% wear and the outside edges is probably 40% wear. Though the tire seems a bit dry, it isn't cracking or splitting or anything like that. I should mention these are Dunlop Q2's.
There seems to be fairly good tread left in the tires but as far as condition goes...will there be any ill effects from a tire that was partially used and then stored for over a year Will I lose traction because the tire compounds have weathered / aged from storage some?
Any feedback would be much appreciated.
Thanks!
Skitch is offline
post #2 of 2 Old 01-02-2014, 05:23 PM
corkoli's Avatar
I Ride: Kawasaki ZX6R '09
Check the sidewall for the production date. It may assist with your decisions.
Tire designations - see bottom of page
corkoli is offline
Time for New Tires. What to get?! pete69zx Mechanical and Technical 856 06-14-2019 04:33 AM
Noob question about tires Kali636 The ZX6R 8 11-22-2013 08:28 PM
I have a question about mixing tires Xperience Motorcycle Talk 29 12-12-2012 06:34 PM
New tires! Sorta odd question DellsNinja The ZX6R 9 08-12-2009 07:06 PM
