2000 Kawasaki ZX6R Running issues - ZX6R Forum
  • 2 Post By zx racer
  • 1 Post By iLean2much
post #1 of 15 Old 08-28-2013, 06:45 PM Thread Starter
nathanknsy's Avatar
I Ride: 2000 Kawasaki Ninja ZX6R
Exclamation 2000 Kawasaki ZX6R Running issues
Hello Everyone,
I recently bought a 2000 ZX6R and am currently restoring it. A project in itself, however I need your help.
Issue 1: The choke lever that should be on the handle bar, next to the horn and light switch is missing the slider deal for the choke is it wiser to replace the whole assembly or just the slider?
Issue 2: The choke is running on full currently so I only start the bike for a couple min, than shut her down so I don't do damage. However today she was having running issues, wouldn't start, just sputter, maybe run for three seconds and die. Why would this be?
Issue 3: After taking her apart the spark plugs were gapped at .032 and the manual says between .07-.08 is this true? They are NGK spark plugs.
Issue 4: A little white smoke came out after like 15 seconds disappeared and she smells really rich how can I fix this?
Note: Also after re-assembly she shot a couple of flames should I be worried?
nathanknsy is offline
post #2 of 15 Old 08-28-2013, 06:51 PM
iLean2much's Avatar
I Ride: 2006 Zx636 / 2001 Zx6R
if it's been running on choke most of the time, then flames might be because of unburned fuel getting into exhaust.
you probably run cheaper getting that whole assembly than just that one lever OEM from a dealer.
you should have tons of parts available since there was a ZZR600 from 2005-08. Probably around $10 + shipping.
manual goes by metric i.e. 0.08mm is around .0315 inch
More important is the colour of your spark plugs, once you got the choke fixed. They're probably pretty black right now.
Always make sure you get frsh gas. Condensation builds up over a few months, especially if the tank wasn't filled to the brim. even worse after the gas gets past 2 months of sitting WITHOUT fuel stabilizer.
iLean2much is offline
post #3 of 15 Old 08-28-2013, 06:56 PM Thread Starter
nathanknsy's Avatar
Yes they were black cleaned, I cleaned them and put them back in, I will by the assembly than. Also when I took her apart I noticed the vacuum lines going into what looks like carbs were detached I re-attached them. How ever I just got the bike and there was very little gas in it when I got it, so I pit premium fuel in like a gallon and a half and a little gas treatment was I wrong for not just draining the tank or am I ok for now.
post #4 of 15 Old 08-28-2013, 07:02 PM
zx racer's Avatar
I Ride: 04 ZX636
i have the choke lever/cable along with bunch of other parts off a 02 zx6r im parting out. here is the link below to the add if you need any parts.
https://zx6r.com/classifieds/47396-98...tout-pics.html
iLean2much and nathanknsy like this.
zx racer is offline
post #5 of 15 Old 08-28-2013, 07:06 PM
iLean2much's Avatar
depends on if the float bowls where drained.
i've seen residue, dried up gas on the walls of a float bowl. could look through the needles but bike ran like crap. i put in new needles and the plug that shuts off fuel supply once the float hit that pin (old one was pissing fuel in closed state). It was just a rebuild kit with new O rings and needles. did it all.
there is a slide mounted underneath the carbs that opens pins on all 4 of them to enritchen the mixture fora cold engine start up.
you can work it manually with some pliers from the left side where you see the throttle cables and of course the choke cable.
2001 Kawasaki NINJA ZX-6R (ZX600-J2) Carburetor | Babbitts Kawasaki Parts House
Part# 13168
nathanknsy likes this.
post #6 of 15 Old 08-29-2013, 09:10 AM Thread Starter
nathanknsy's Avatar
Another thing, this bike has been laid down you can tel by the lutch and generator covers all scratched up, however i cant figure out what this part is called. It connects from my frame in the frong around the gas tank to the fairing where the mirrors are held on. it looks like a H is it a fairing support system?
post #7 of 15 Old 08-29-2013, 09:18 AM
iLean2much's Avatar
it's the upper fairing stay.
zzr 600 models 05-08 don't have it anymore as they smartened up and just extended the inner cluster stay that bolts on the the steering stem, to bolt on to the mirrors.
I found my H to be handy at times, tying take out or small grocery bag to it LOL
post #8 of 15 Old 08-29-2013, 09:25 AM Thread Starter
nathanknsy's Avatar
Where can i buy a new one it was damaged i assume from one of the accidents?
post #9 of 15 Old 08-29-2013, 09:41 AM
iLean2much's Avatar
keep your eyes open on ebay!
ZZR600 ZZR 600 05 06 07 08 Upper Fairing Stay Bracket | eBay
You can tell apart the oem from the chinese copies. I had 2 chinese versions, didn't bolt on directly, had to drill out the holes, where wobbly and needed washes squeezed in on the inside. Plus they broke off on the mirrors very quick.
OEM has that triangle hole in the middle, chinese is solid.
OEM
chinese
post #10 of 15 Old 08-29-2013, 10:17 AM Thread Starter
nathanknsy's Avatar
mine looks nothing like that one i think someone rigged these bars i will post a pic in a little while.
2003 Kawasaki ZX12R - Sold
2005 Kawasaki Ninja 250 - Sold
2000 Kawasaki ZX6R - Currently owned
post #11 of 15 Old 08-29-2013, 10:18 AM
iLean2much's Avatar
this is the upgraded version, eliminating that H between cockpit and tank!
you probably mean this Mirror Bracket
http://www.ebay.com/itm/new-Kawasaki...d052a9&vxp=mtr
post #12 of 15 Old 08-29-2013, 10:31 AM Thread Starter
nathanknsy's Avatar
Indeed, you are correct so is the other one is better?
post #13 of 15 Old 08-29-2013, 10:36 AM
iLean2much's Avatar
other one looks better.
post #14 of 15 Old 08-29-2013, 10:42 AM
zx racer's Avatar
I Ride: 04 ZX636
i have the upper mirror bracket in good shape not bent or nothin if interested.
zx racer is offline
post #15 of 15 Old 08-30-2013, 05:41 AM Thread Starter
nathanknsy's Avatar
where is the best place to get custom decals made for my 00 zx6r?
parts swap for the 6r through out the years scoobs Mechanical and Technical 14 12-15-2016 08:22 AM
kawasaki 2000 zx6r fairing usmcmitchell Want to Buy 5 01-07-2009 10:27 PM
