Over filled coolant reservoir etc help!! - ZX6R Forum
 4Likes
post #1 of 22 Old 08-26-2013, 01:00 PM Thread Starter
kawizx6r743's Avatar
I Ride: 2011 zx6r Green 2009 CRF250r Mod
Ok here's the situation. I wanted to do a coolant flush/change on my 11 zx6r. My issue was that I didn't know how how remove the upper right fairing with out removing the front fairing. Iam crunched on time here with work so decide to drain everything I could from the bottom drain bolt. Which now leads just a little bit in the reservoir. I decide the new coolant will "overtake" the old few ounces.(which it did in my opinion based on the color change-put engine ice in.) my issue is that I wasn't thinking and just about topped off the reservoir.(not the full line but topped off)
Now I need to fill the neck which is damn near impossible to reach with a flexible funnel!!. Now the neck isn't quite topped off yet from what i can feel with my finger but the reservoir is full, like the actual container is from earlier. I ran it till the fan turned on hopeing the bike would suck in what it needed from the reservoir but never did. I'm gonna take the cap off soon to see if it burps the system and lowers the reservoir? Any ideas on what needs to be done besides do it the right way next time??
life begins at 16000rpm
2011 Zx6r--M4 Slip on Exhaust--HotBodies Fender Eliminator--Power commander V--Frame Sliders--Tech Spec C3--K N Airfilter--Hotbodies track plastics--decals
kawizx6r743 is offline
post #2 of 22 Old 08-26-2013, 01:38 PM Thread Starter
It seemed to have went down a small touch prior to me opening the cap. Just from sitting 40 min. But it's still pretty high in the reservoir. Where all the die hard zx6r mechanics out there?!!
post #3 of 22 Old 08-26-2013, 01:47 PM
Sandman's Avatar
As far as I know, you cannot remove the side fairings independently on the 09-12. Both the sides and the front have to come off together before you can split them. That is probably what I hate most about my bike.
Sandman is offline
post #4 of 22 Old 08-26-2013, 02:00 PM
Desertmach's Avatar
I Ride: Yam FZ1 Kaw Z1000
Maybe drain a little from the bottom of the bike, but not to much, then run engine till it gets hot then let it cool to draw the coolant out of the overflow back into the motot ? only way I can think of without getting to the overflow tank to cyphon it out.
Maybe others will have better ideas, good luck.
Desertmach is offline
post #5 of 22 Old 08-26-2013, 02:18 PM
Fred's Avatar
I Ride: '12 Green ZX-6R
Doesn't the overflow reservoir have it's own overflow tube to drain away excess fluid on it's own?
Scorpi0 and laggy311 like this.
Fred is offline
post #6 of 22 Old 08-26-2013, 02:55 PM
AlexZX6R's Avatar
If your radiator is full and the fan comes on, the temps are normal but your overflow is too full. Just use a turkey baster to draw out the excess. No need to have your cooling system purge all the excess to the asphalt and cause an unsafe slippery condition. That's just me though.
AlexZX6R is offline
post #7 of 22 Old 08-26-2013, 03:10 PM
pokinarrow's Avatar
I Ride: 2012zx6r
^this. Or you can rag dip it several times.
pokinarrow is offline
post #8 of 22 Old 08-26-2013, 04:31 PM
Whats wrong with having the overflow full??
Scorpi0 is online now
post #9 of 22 Old 08-26-2013, 05:10 PM
laggy311's Avatar
I Ride: Dirty
Dude, dip paper towel in there. But the overflow bottle has an overflow tube. you're good.
laggy311 is offline
post #10 of 22 Old 08-26-2013, 05:25 PM Thread Starter
Thnk you guys. Ill check to see if if has that hose. If not, ill try the other ideas
post #11 of 22 Old 08-26-2013, 05:27 PM
AlexZX6R's Avatar
Dipping is not professional. It is messy. It is not the safe way. If you want to dip. Why not just stick a tampon or maxi pad in there? Same result. Still messy and not safe.
AlexZX6R is offline
post #12 of 22 Old 08-26-2013, 05:29 PM
AlexZX6R's Avatar
Too full, or over filled is the problem.
AlexZX6R is offline
post #13 of 22 Old 08-26-2013, 06:00 PM
Whats the downside of having it overfilled?
post #14 of 22 Old 08-26-2013, 06:12 PM
AlexZX6R's Avatar
I don't think you want coolant dumping under your ride while you are riding. At any speed. Very unsafe.
AlexZX6R is offline
post #15 of 22 Old 08-26-2013, 06:17 PM
Duane S's Avatar
nvm
Duane S is offline
Does the coolant reservoir have an overflow? d1andonlyant Mechanical and Technical 7 06-06-2013 10:34 AM
Brake Reservoir / Coolant Reservoir. Where to buy. ICHIBAN The ZX6R 0 11-14-2011 07:58 PM
Coolant Reservoir zygzyphr Mechanical and Technical 0 09-06-2011 06:57 PM
