04 ZX6R eletrical problems in turn signals... - ZX6R Forum
 5Likes
  • 3 Post By kevinRR
  • 2 Post By Scorpi0
post #1 of 5 Old 08-24-2013, 11:51 AM Thread Starter
Flash636's Avatar
I Ride: 04 ZX6R
Question 04 ZX6R eletrical problems in turn signals...
Hi guys, how're you doing?
I didn't find a thread on the mechanical forum to answer this so I'm starting this one.
So today I was wiring my mirrors' LED blinkers when I realized that the rear left turn signal wasn't working (I have mounted all the turn signals and plate light myself and did my own plate holder, so it was very strange it was failing...).
Turns out, the LED turn signal itself had one of the wires hanging out, I mean, there was only one wire coming out from the LED instead of 2, and the other one was simply disconnected I have no idea how it happened but I'm calling the seller on Monday first thing in the morning as they were bought like a month ago!
Then I tried to fix the turn signal, it just needed a little welding and we're good to go. But as I didn't know the right place to weld it (inside the blinker) I thought I would simply try to touch the wire on several spots until I have the blinker working again and then weld the wire there, reasemble the LED and ride the hell out of my baby.
That's where the strange thing happened... I touched with the wire on one of the weld spots on the circuit board and I heard a click and also the tail light blinked. Now I don't have turn signals at all
It doesn't even show on the cockpit the turn signals when activated...
Tried to change the relay, as I still have the original (at the moment I have a TST Industries one because of all the LED) and still no good...
Have anyone experienced this or have any clue if I messed up pretty bad? lol
Thanks in advance.
Flash636 is offline
post #2 of 5 Old 08-24-2013, 12:40 PM
I Ride: 2011 zx6r
Sounds like you blew a fuse, that the first thing I would check.
Scorpi0, MonkeyWrench and Flash636 like this.
kevinRR is offline
post #3 of 5 Old 08-24-2013, 07:14 PM
I think you connected your positive blinker wire straight to ground causing your fuse to blow. Change the fuse and open up the blinker on the other side to see where that wire goes.
Street Hawk1 and Flash636 like this.
post #4 of 5 Old 08-26-2013, 02:42 AM Thread Starter
Flash636's Avatar
I Ride: 04 ZX6R
wow, how come I didn't think about that??!!!
thank you SOOOO MUCH for helping me out, I'll definately check the fuse!
Flash636 is offline
post #5 of 5 Old 08-27-2013, 02:17 AM Thread Starter
Flash636's Avatar
I Ride: 04 ZX6R
Hey guys, just wanted to say that the fuse was actually blown. I replaced it and everything is back to normal!
Thank you very much once again, you've helped me out and saved me from going to the shop! lol
Flash636 is offline
Turn signals gone crazy 05bluezx6r The ZX6R 2 06-11-2013 07:14 AM
Just got pulled over for no rear turn signals, Any Ideas on what turn signals to get? GGEENN The ZX6R 2 08-21-2012 02:35 PM
need turn signals 95-97 zx6r osageinmt Want to Buy 0 04-15-2009 07:35 PM
