striped screws and bolts everywhere! - ZX6R Forum
 6Likes
  • 1 Post By beckzach05
  • 3 Post By SSGSXR ZX6R
  • 1 Post By gsxrdoug
  • 1 Post By boloson
post #1 of 12 Old 06-28-2013, 08:58 AM Thread Starter
soooo basically it looks like almost every damn bolt and screw is fucked.. my guess is previous owner left it outside always.... I went to replace the grips... stripped bolt.... went to replace the lever... srtipped nut and screw... whats the best thing I should do.. what tool/ tools? bring to mechanic and replace everything? I want to start fresh because it is realllyyy bothering me
samnjd is offline
post #2 of 12 Old 06-28-2013, 09:00 AM
SSGSXR ZX6R's Avatar
I Ride: 05' GSXR 1000 05' GSXR 600 04' ZX6RR
Either that or you are using the wrong size allen...
My bike has sat outside since December... Snow, salt, rain, bird poop....
I had no issues besides my clutch lever which had some surface rust in the pin which made it hard to push out.
SSGSXR ZX6R is offline
post #3 of 12 Old 06-28-2013, 09:03 AM Thread Starter
they are def stripped lol...im not that dumb
samnjd is offline
post #4 of 12 Old 06-28-2013, 09:06 AM
Never said you were dumb, just pointing out if you use the wrong size that "works" to remove them but is not a tight fit than it'll strip
But anyways what you are saying is you would like to know where to get a bolt kit from for your bike?
post #5 of 12 Old 06-28-2013, 09:12 AM
was also thinkng instead of using socket wrench to use adjustabe wrench with teeth to grab the bolt
Gee, I wonder how those stripped.
jayboy131 likes this.
beckzach05 is offline
post #6 of 12 Old 06-28-2013, 09:41 AM
Guttermouth Ragdoll
MistressOfMayhem's Avatar
I Ride: 04 ZX6-R, 2019 KLX 250 - \m/urdered Out Edition, 07 FZ-06
Interesting...
Well I would say to go onto bikebolts.com and order another set for the fairings of your bike. Then just replace them all. You aren't going to get the bigger bolts like for the frame, calipers, pinch bolts, etc. But you can get those from the local shop OR you can order them online using a parts fiche.
Hiring a mechanic to remove bolts seems a little over-the-top.
MistressOfMayhem is offline
post #7 of 12 Old 06-28-2013, 10:01 AM
Nickoli's Avatar
I Ride: 08 ZX6R
Is it just the heads that are bad and rounded/stripped out? Or are you talking about threads? You could invest in a set of left handed drill bits and easy outs, they do help a lot. sometimes the drill bit will bet the bolt and it comes out easy, other times youre not so lucky.
Nickoli is offline
post #8 of 12 Old 06-28-2013, 10:31 AM Thread Starter
yeah the heads the thread is fine.. yeah I just talked to a buddy of mine and he said the same thing or try jamming a flathead in there and twisting he said also .. thanks for the help bud
samnjd is offline
post #9 of 12 Old 06-28-2013, 10:33 AM
I vote for getting proper tools...
MrZ, beckzach05 and 636MOBIN like this.
post #10 of 12 Old 06-28-2013, 02:02 PM
I Ride: 07 ZX6R
First use some PB blaster to help free them then on the stripped ones you are going to need an easy out or like tool that grabs the stripped head. But soak the threads first, will pay off in the long run. And like a lot of people have already said proper tools.
636MOBIN likes this.
gsxrdoug is offline
post #11 of 12 Old 06-28-2013, 02:12 PM
boloson's Avatar
Sell the bike?
beckzach05 likes this.
boloson is offline
post #12 of 12 Old 06-28-2013, 04:28 PM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
Agree on that, there are many low quality tools out there, check your allen keys, if the edges are slightly round, there is the reason you are stripping bolts.
MrZ is offline
Bike bolts Shrekzx6 Mechanical and Technical 17 10-09-2012 08:48 PM
07-08 Bolts and screws (pictures inside!) Lobster Want to Buy 5 03-07-2012 01:11 PM
Carb bolts arron Mechanical and Technical 10 08-01-2011 08:01 AM
