butterfly on exhaust - ZX6R Forum
  • 1 Post By Scorpi0
post #1 of 8 Old 06-28-2013, 12:06 AM Thread Starter
I Ride: 2012 zx6r
Wassup ppl.. I tried putting my stock exhaust back on my bike today and ran into a problem with the two wires that connect to the butterfly thats on the exhaust. One of the wires is just stuck and dosent give me no slack to be able to hook it back up on the lil butterfly.any help on how I can get that wire loose to connect it back ?
zzzxx66rr is offline
post #2 of 8 Old 06-28-2013, 12:40 AM
Turn the key on. The servo should do its operational check. As it does this the wire should become loose. Tuen the key back to off half way thru the operational check and itll stop in the loose position.
zand3r likes this.
post #3 of 8 Old 06-28-2013, 06:12 AM
soloxplorer's Avatar
I Ride: 2011 "team green"
Don't worry about connecting the cables back up, the butterfly valve will remain open and it will have no noticeable impact on performance. About the only thing you'll get out of it is a slightly louder idle.
https://zx6r.com/zx6r/44855-because-e...ree-stuff.html
soloxplorer is offline
post #4 of 8 Old 06-28-2013, 10:18 AM Thread Starter
I Ride: 2012 zx6r
Well the wire seems to be stuck ! I turn on the key , but the servo doesn't loosen up one of the wires . And now my FI light is blinking
post #5 of 8 Old 06-28-2013, 11:33 AM
Gotta find where the cable is binding and work it free. It's possible too that you may have put the wrong end from the servo onto the valve, where the servo is pulling on something that can't move. The FI light is on perhaps due to the servo motor being unable to complete it's cycle.
post #6 of 8 Old 06-28-2013, 11:41 AM Thread Starter
I Ride: 2012 zx6r
Yea I'm sure the light is on due to the servo. Haven't checked the code yet, but that has to be it. It dosent affect it if I run the bike like that right ?
post #7 of 8 Old 06-28-2013, 12:15 PM
Didn't need two thread for the same issue.
https://zx6r.com/mechanical-technical...tor-stuck.html
beckzach05 is offline
post #8 of 8 Old 06-28-2013, 03:00 PM Thread Starter
I Ride: 2012 zx6r
Its giving me Fi code 63
exhaust butterfly power increase or decrease T.E.Shuler The ZX6R 26 06-05-2013 06:27 PM
Exhaust Butterfly Valve Actuator Ginget T Mechanical and Technical 6 01-18-2013 12:18 AM
How to: Install Danmoto Exhaust (and baffle) Chaos Guides 9 06-12-2011 05:43 PM
