Spark Plugs - ZX6R Forum
post #1 of 12 Old 11-18-2011, 06:04 PM Thread Starter
pito5260200's Avatar
I Ride: 2005 ZX6-R
Spark Plugs
Hey guys and ladies i own a 2002 ZX6-R and I'm wondering if anybody has try the E3 spark plugs. Is it worth getting.
Your Work Is Your Signature
pito5260200 is offline
post #2 of 12 Old 11-18-2011, 06:31 PM
zx racer's Avatar
I Ride: 04 ZX636
waist of money. stick to oem NGK.
zx racer is online now
post #3 of 12 Old 11-18-2011, 06:39 PM
NuggetNik's Avatar
I Ride: 2001 Blue J2 ZX6R
NGK FTW! lol
Originally Posted by TXZX6R View Post
WTF Nugget... I thought they were suppose to fix your brain?? You seem A LOT more fucked up now... YOU FUCKEN WEIRDO! bahahahahahaha
Big Up The "Fizzy Gravy" Club
NuggetNik is offline
post #4 of 12 Old 11-18-2011, 06:54 PM Thread Starter
I Ride: 2005 ZX6-R
Ok Thanks for the info. Any particular V Power, G Power, Iridium, Laser Platinum, Laser Iridium
post #5 of 12 Old 11-22-2011, 10:41 AM
Bensbaby's Avatar
I Ride: 2002 Kawasaki zx6r
i just get stock ngk copper core cr9e i believe.
gap them right.
and if you really want to be hardcore...index them.
indexing spark plugs helps...for more hp.
Yoshi RS3 exhaust, K&N Intake, -1 +2 rear and oring chain, Dynojet carb kit, Factory Pro timing advancer, Rear lowering links 1" and front lowered 1", Rear Tire hugger, carbon fiber mirrors, smoke window, Aftermarket levers and grips and chrome bar ends, and wet NOS KIT. DYNOTUNE NOS controller. External 2nd fuel pump 250hp dynotune
Bensbaby is offline
post #6 of 12 Old 11-22-2011, 08:50 PM Thread Starter
I Ride: 2005 ZX6-R
How hard is it to index the spark plugs.
post #7 of 12 Old 11-22-2011, 08:53 PM
ZX6RRECTION's Avatar
Very easy...
I Think laser iridium
ZX6RRECTION is offline
post #8 of 12 Old 11-22-2011, 08:56 PM Thread Starter
I Ride: 2005 ZX6-R
laser iridium would b the best choose for a 02 zx6r?
post #9 of 12 Old 11-22-2011, 09:07 PM
Bensbaby's Avatar
indexing spark plugs is a old school idea.
its been around for YEARS.
you need to put the plug in the socket and mark the top of the socket with a marker so you know the posistion of the spark plug tip.
bascially you want to turn it in to its home knowing where the tip is ...
you want to stop the tip so the open part of the tip is faceing the intake valves .
its tricky sometimes you need to take plugs out and switch them around to get it right.
but its a old school trick.
and all it does it make sure that the open gap faces the intake valves...
its supposed to prevent spark blow out and all this and even some ppl saw a increase in hp...very minor...but still
i do it to my car
Bensbaby is offline
post #10 of 12 Old 11-23-2011, 08:21 AM Thread Starter
I Ride: 2005 ZX6-R
Thanks it doesn't sound hard I appreciate the knowledge.
So NGK Laser Iridium is the way to go?
post #11 of 12 Old 11-23-2011, 10:32 AM
Bensbaby's Avatar
hoestly i just get the cheap copper core ngk plugs...
Bensbaby is offline
post #12 of 12 Old 11-23-2011, 01:54 PM
zx racer's Avatar
I Ride: 04 ZX636
yes if you want to fork over the extra $$$ for them if not good ol ngk cr9e will work also.
spark plugs question Cap Walker The ZX6R 22 02-24-2013 04:28 PM
Help changing Spark Plugs mounty50 Mechanical and Technical 3 09-20-2011 02:46 PM
E3 spark plugs sportryder Mechanical and Technical 15 07-07-2011 09:10 AM
Spark Plugs bcroninuk Mechanical and Technical 4 05-13-2011 09:40 AM
Spark plugs nlutfi Mechanical and Technical 8 03-15-2011 07:37 PM
