Couple of problems:( - ZX6R Forum
post #1 of 12 Old 07-26-2011, 12:09 PM Thread Starter
waynster's Avatar
I Ride: zx6r g1
Hi all, got a couple of problems with my new bike...1st when i put bike into 1st gear from stand still it jumps forward and clicks a few times...2nd my rear shock is leaking a sticky grease...any idea what the problems are?? cheers.
waynster is offline
post #2 of 12 Old 07-26-2011, 12:13 PM
givuhcky22's Avatar
I Ride: 2015 636 Carbon Grey
most bikes have a light jerk or jump when you put it into 1st. as for the clicking afterwards, i'd have to hear it to know what youre talking about.
and if you've got a leak and can do work yourself, investigate. pull thing apart and check.
or take it to a shop
givuhcky22 is offline
post #3 of 12 Old 07-26-2011, 12:18 PM Thread Starter
waynster's Avatar
I Ride: zx6r g1
The clicking is the bike trying to find the gear!! instead of having 1 clunk when you pop it into gear it clunks a few times...
waynster is offline
post #4 of 12 Old 07-26-2011, 12:32 PM
givuhcky22's Avatar
old chain/sprockets?
post #5 of 12 Old 07-26-2011, 01:40 PM
Mine has clunked a little into gear since day one. Try changing your oil... it might help.
As for the "sticky" fuid on your rear shock... clean in off... then clean EVERYTHING around it... clean and lubed the chain... go for a ride... and see if you're getting excess chain lube in that area.
Chain lube is sticky... just going from what I know.. haha.
PowerGroove is offline
post #6 of 12 Old 07-26-2011, 02:24 PM Thread Starter
waynster's Avatar
I Ride: zx6r g1
Thanks for the replies...i will try the things you have suggested...will let you know how it goes
waynster is offline
post #7 of 12 Old 07-26-2011, 03:02 PM
Might want to check your clutch and see if it's out of adjustment while you're tinkering. That'll make it buck a little when going into gear if the clutch isn't fully disengaging.
post #8 of 12 Old 07-27-2011, 07:58 PM
pegleg's Avatar
I Ride: ZX6R and a few more
^+1
Make sure your clutch is adjusted correctly.
As PowerGroove said, clean everything spotless first then take it for a ride and see where it leaks.
pegleg is offline
post #9 of 12 Old 07-27-2011, 08:30 PM
ZX6RRECTION's Avatar
If you're revving too high or releasing clutch too slow...you'll engage the slipper ...I tink
ZX6RRECTION is offline
post #10 of 12 Old 07-27-2011, 08:33 PM
totally sounds like a clutch adjustment issue
rear shock may need to be rebuilt
steverparker is offline
post #11 of 12 Old 07-28-2011, 09:05 AM
mtp
mtp's Avatar
slight clutch adjustment maybe and sounds like road dirt and chain lube
ZX6R, 97 plate streetfighter on the road, home made roll cage... GSXR 1100 streetfighter project, busa swing arm, ZX6R seat unit subframe home made, top yolks home made etc etc
mtp is offline
post #12 of 12 Old 07-28-2011, 02:22 PM Thread Starter
waynster's Avatar
I Ride: zx6r g1
Hi guys...quick update, took my bike back to dealer...had my money back and got my g1 back...i have to say my g1 is so much easier to ride...everything is so much smoother!! oh yeah the gearbox was fooked!! thanks again for advise
waynster is offline
couple pics after having a drunkn night...6r content vividlust Motorcycle Talk 27 02-03-2012 12:18 PM
99 ZX6R, New but some problems HELP psilo The ZX6R 7 06-12-2011 07:29 AM
A Couple of Problems and Alot of Frustration!!! seank Mechanical and Technical 18 06-01-2011 03:29 AM
