Front tire click noise - ZX6R Forum
post #1 of 11 Old 04-08-2011, 02:17 PM Thread Starter
AxKaN's Avatar
I Ride: ZX6-R
Ok so just last week I started hearing this clicking noise coming from my front tire... I can only hear it when im either going in 1st gear, very slowly, or neutral moving forward with my feet...
any ideas what this clicking sound might be?
AxKaN is offline
post #2 of 11 Old 04-08-2011, 02:28 PM
wiffy's Avatar
I Ride: mountain bike
first thing start with tyer all round mite be nail stone glass,nexy check pads and calipers could have some thing cought up in there next mud gaurd cracks debrie from road,good luck.
dyslexia and adhd dont make for good spelling or gramer
wiffy is offline
post #3 of 11 Old 04-08-2011, 02:50 PM
bradlee08's Avatar
I Ride: 2004 kawasaki zx-6r
did you recently have any work done to it? make sure brake pads in front are seated correctly. check the tension bolts on bottom of forks should be tight. if nothing else maybe take off front tire and check ur axel, and your bearings
Pc3
yosh slip-on
_sometimes pinebox
KLEEN air mod
K&N air filter
05 swingarm and rim conversion
STOMP tank pads
Blue backlit gauge
integrated tail light
smoked signals
bradlee08 is offline
post #4 of 11 Old 04-08-2011, 03:26 PM Thread Starter
AxKaN's Avatar
I Ride: ZX6-R
Thank you guys
AxKaN is offline
post #5 of 11 Old 04-08-2011, 03:33 PM
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
What they said^
You need to get the wheel of the ground so you can spin it & listen for the click.
You should be able to locate the source easy enough.
read only one page"
oldninjadude is offline
post #6 of 11 Old 04-08-2011, 03:34 PM
bradlee08's Avatar
do you have a front fork stand? if not a jack will work
Pc3
yosh slip-on
_sometimes pinebox
KLEEN air mod
K&N air filter
STOMP tank pads
Blue backlit gauge
smoked signals
post #7 of 11 Old 04-08-2011, 03:50 PM Thread Starter
AxKaN's Avatar
I Ride: ZX6-R
Yeah ill have to use a jack but ill check it out because I want to get this fixed before I sell it
AxKaN is offline
post #8 of 11 Old 04-08-2011, 06:30 PM
bradlee08's Avatar
Sell?! you gettin rid of it or getting different bike?
Pc3
yosh slip-on
_sometimes pinebox
KLEEN air mod
K&N air filter
STOMP tank pads
Blue backlit gauge
smoked signals
post #9 of 11 Old 04-09-2011, 03:59 PM Thread Starter
AxKaN's Avatar
I Ride: ZX6-R
Unfortunately, this bike has been giving me many problems recently... I feel like it let me down... I will look for another zx6r, maybe a newer one
AxKaN is offline
post #10 of 11 Old 04-09-2011, 06:32 PM
bradlee08's Avatar
ya problem with older bikes is if they didnt get properly maintained problems arise as soon as the person sells it lol
glad to hear it hasnt deterred you away from kawi's, what model you thinking of? id highly recomend the 03/4, not as pricey as the newer ones, still keeps up in looks and performance imo
Pc3
yosh slip-on
_sometimes pinebox
KLEEN air mod
K&N air filter
STOMP tank pads
Blue backlit gauge
smoked signals
post #11 of 11 Old 04-09-2011, 09:56 PM Thread Starter
AxKaN's Avatar
I Ride: ZX6-R
Ill see if I can find one around, def going to get another zx6r
AxKaN is offline
click from front end on light braking BadAssRX-7 The ZX6R 15 12-22-2016 04:27 PM
Bohemian Racing Adjustable Rearsets ZX6R Kevin2109 The ZX6R 130 12-26-2013 06:04 PM
Squeaking noise from front tire propaintball Mechanical and Technical 7 02-07-2012 06:38 PM
brand new 2011 zx6r... rubbing noise from front tire boyscouT The ZX6R 16 08-05-2011 03:53 PM
