Weird clutch issue - clicking 2013 zx6r - ZX6R Forum
 7Likes
post #1 of 16 Old 12-11-2019, 07:17 AM Thread Starter
Unhappy Weird clutch issue - clicking 2013 zx6r
Hey guys, at wits end trying to workout what the issue is with my bike. When i pull the clutch lever in, release it and repeat the process in first gear it starts making a "click sound", and the bike feels like it wants to slightly jolt forward. It also does the same thing when in second gear when the RPMS are low (3-4k) and i pull the clutch lever in and then release it i get the click sound;
https://imgur.com/a/rNYKJXU Watch from 00:06 for a good example of the issue.
Sounds like it's coming from either the middle of the engine, or coming from the left side of the bike. Anyone know if this is normal?
zzxxrrrr is offline
post #2 of 16 Old 12-11-2019, 07:59 AM
Can't watch the video at work..... mechanical things make noise. Parts that have gaps between them make noise when they go together. First thing I would do is change your oil to fresh. That may provide more 'cushion' when parts make contact.
A clutch stack on a motorcycle has multiple friction and pressure plates layered together. Half of them (all the frictions, or all the pressure plates) have tabs that slot into splines on the inside edge. The other half of the stack has tabs/splines on the outside edge. The tabs have a gap to the points they hit. you can hear noise from that space getting consumed. The pairs of gears have dogs and slots on adjoining gear pairs. There is some gap there as well.
The slipper assembly in the clutch can also make some amount of noise, as that is another way to spread the stack out to allow the transmission to slip.
Your chain may be worn. Your sprockets may be worn.
Lots of things to check.
Words to live by
post #3 of 16 Old 12-11-2019, 12:21 PM
I Ride: '12 ZX6
Sounds more like chain slap than anything, but near impossible to diagnose over the internet
riverszzr and Gawernator like this.
WERA Expert #37
N2 Track Days Control Rider
'07 ZX6
Sportbike Track Gear
Woodcraft
Andrew Swenson Design
N2 Track Days
Otto Man is offline
post #4 of 16 Old 12-11-2019, 05:14 PM
Can you feel the “click”? Or just hear it?
post #5 of 16 Old 12-11-2019, 06:58 PM Thread Starter
Checked on a few things, chain and sprocket seem good. The only thing i noticed was the chain was a little loose - i tightened it not too long ago
Can you feel when this happens? and would it even be noticeable in first gear when only letting out the clutch with no throttle?
I can feel it as well.
zzxxrrrr is offline
post #6 of 16 Old 12-12-2019, 02:26 AM
Definitely not chain slap. Sounds like something is binding somewhere. Gotta figure out if its internal or something external like the lever, cable, or arm.
Scorpi0 is online now
post #7 of 16 Old 12-12-2019, 11:52 AM
Chain? tight and loose spots- uneven wear is my guess based on that
But who the fuck knows from a video on the internets......
How many miles on the bike
How long have you owned it
what has been its use, abused, babied, coddled, well cared for, beat to fuck and put away wet
Do you have mechanical abilities or just enough to get you in trouble
Otto Man and Strider like this.
post #8 of 16 Old 12-12-2019, 05:45 PM
I Ride: '12 ZX6
Watched it a few more times and I'm still convinced it's chain related. There's a reason it seems it can't be replicated when he's taking off from a stand still, only when he pulls the lever in while moving. The chain is taunt on the top side while driving, he pulls the clutch in, and the chain from the under side of the swingarm is slapping against the plastic chain guide on the bottom of the swingarm.
WERA Expert #37
'07 ZX6
Woodcraft
N2 Track Days
Otto Man is offline
post #9 of 16 Old 12-12-2019, 07:49 PM
zx6rguiy's Avatar
This /\
If you are not convinced, cut your chain off and see if it still makes the noise. And since you just cut the chain off, might as well buy a new one.
riverszzr likes this.
zx6rguiy is offline
post #10 of 16 Old 12-12-2019, 09:23 PM
I Ride: '12 ZX6
Originally Posted by zx6rguiy View Post
This /\
This got me thinking as well. You could find out real fast by putting it on a rear stand and letting the clutch out and see if the noise can be replicated
WERA Expert #37
'07 ZX6
Woodcraft
N2 Track Days
Otto Man is offline
post #11 of 16 Old 12-13-2019, 12:25 AM
When I had weird clicking/popping noises like that a while back, it was because of a worn out chain, and it was making noises on the rear sprocket. The fact that it makes the noise when you use the clutch lever could be just coincidence.
Strider is online now
post #12 of 16 Old 12-13-2019, 05:48 AM
I dont think its the chain because u can actually see the click in the lever motion.
Duc995 likes this.
post #13 of 16 Old 12-13-2019, 06:24 PM
zx6rguiy's Avatar
Looks like hes just pulling the lever in and out. The fact that the noise coincides with the movement of the clutch lever would lead me to believe even more that its the chain. As the drive is being connected and disconnected from the output shaft, a load is being applied and removed to the chain. The guy also said the noise was coming from the middle or the left side of the bike. Taking into account the fact that most riders severely neglect their chains, I would bet big money this is just chain slap.
zx6rguiy is offline
post #14 of 16 Old 12-13-2019, 06:54 PM
OP, chains do not wear evenly. They get loose in sections that get longer and longer as the damage increases. How many miles are on that chain and sprockets?
Anything over 10-12K miles could be enough to kill it, depending upon maintenance. More neglect means shorter life.
Words to live by
post #15 of 16 Old 12-13-2019, 10:50 PM Thread Starter
I noticed my chain does get a bit loose very quickly but it's all lubed up, the bike has only done about 15,000 miles, only owned it for a few months, last owner used it only as a street bike and i just had valves checked etc.. and everything is perfect on the bike.
I will try this tonight. Although on the video when you listen closely at 00:06 it sounds like the type of noise when you go from N-1, it's a click and you feel it throughout the bike. Can a bad chain really effect it this much?
Pretty much seems to be with the movement, i feel as soon as the clutch grabs it clicks. It's very noticeable when in first gear and i let out the clutch and then pull it back in again. Same thing when in second gear and I'm letting the RPMS drop (traffic in front) and pull in the clutch and hold it and as soon as the cars start moving again within seconds i release the clutch and i hear the click which i can feel in the handlebars. Going full throttle etc.. i get no issues with the transmission, nothing slips out and so forth.
zzxxrrrr is offline
