What is the difference between ZZR600 and ZX6r carbs? - ZX6R Forum
  • 1 Post By riverszzr
  • 1 Post By WildCard
post #1 of 7 Old 12-06-2019, 05:46 PM Thread Starter
Question What is the difference between ZZR600 and ZX6r carbs?
I have read that they are interchangeable, but they look different. What are the harnesses on the ZZR carbs connected to? I have an 01 ZX6r and my carbs look like the attached pic. Then there is this eBay listing..
https://www.ebay.com/itm/Kawasaki-00...YAAOSwJkVdzcDU
My bike has been sitting about 10 years now and last time I tried to start it in about 2013 it had a ton of trouble starting and I couldn't get it to stay running without the choke on. Pulled the carbs thinking I'd clean the pilots and wound up letting them sit in my shop for 6 years. I don;t really want to deal with them so do you guys think it's smarter to just buy another set, clean the pilots, or pay someone to rebuild and sunc them? Is there an mail in service you guys can recommend? I think I bit off more than I can chew but I really want to get back riding next season.
phreaktor is offline
post #2 of 7 Old 12-06-2019, 05:50 PM
WildCard's Avatar
No difference as far as I know. The ones in the ebay listing are California spec carbs. Those are fuel cut solenoids for the float bowls, emissions crap.
( •_•)
( •_•)>⌐■-■
(⌐■_■)
Roads. ☢
WildCard is online now
post #3 of 7 Old 12-06-2019, 06:07 PM Thread Starter
Ohhh ok. So would they work with those harnesses just disconnected? The seller sent me an offer and I'll jump on it if I can use them.
post #4 of 7 Old 12-06-2019, 06:49 PM
2002 ZX6R and 2005-2008 ZZR600 carbs are the same.........
2001 and older are 1mm smaller ID
but as mentioned those are commifornia spec carbs with fuel cut offs if tipped over
Even those Ebay cards for $135 are going to need at minimum to be cleaned and I would highly suggest replacing the o-rings (so if you did it yourself you would still be 200ish or if you pay someone- you could be 350-400ish)
I bet for the same monies or less you can actually get your carbs cleaned and working well (and by the time you pay someone and buy some parts and even with shipping -if you shipped) I doubt you end up over 350)
Take off one of the float bowls and take a pick close up enough to view easily to see how bad they look inside
I mean if you wanted them professionally cleaned and rebuilt I would do it, parts is parts though and I can only speculate what parts it would need
--do the slides slide up and down now?
--are the needles all green when you do lift the slide and look inside?
-- what does the inside look like
just for some example pricing.......
needle/seat and new o-ring is about $25 x 4 of them.......... but if all you need is the 4 o-rings you are about $8 for the 4
float bowl o-rings are about $7 each x 4
the fuel line junction o-rings between the carbs are maybe another $10
loose carbs that aren't horrific I generally charge $150 for a inline 4 to clean
just a guess but if you had $25 shipping each way............. that gets you right at $350 with new needle/seats & the other requisiste o-rings or $280ish with just all new o-rings
Do you have a jet kit or anything in yours?
WildCard likes this.
post #5 of 7 Old 12-06-2019, 10:54 PM
WildCard's Avatar
SNIP
So the 2002+ have 27mm carbs ? Learn something new everyday.
Sorry, don't want to highjack the thread.
( •_•)
( •_•)>⌐■-■
(⌐■_■)
Roads. ☢
post #6 of 7 Old 12-07-2019, 12:21 AM
BDSR 37mm on the 2002 and all 2005-08 ZZR600's
36mm on the 2001 and earlier
post #7 of 7 Old 12-07-2019, 12:32 AM
WildCard's Avatar
Whoops.. typo on my part. I was thinking all had the 36mm carbs. Good info. Thanks.
riverszzr likes this.
( •_•)
( •_•)>⌐■-■
(⌐■_■)
Roads. ☢
