Shopping for a better rear shock - ZX6R Forum
 10Likes
post #1 of 25 Old 11-29-2019, 02:14 PM Thread Starter
I've told my darling wife that the $57 OEM '13+ used shock I bought as a band aid is nearing it's end of useful life and that I wanted to replace with a new aftermarket shock.
We're budgeting ~$400. If you are able to point me at what my options are at that price point, and give a recommendation as to why you'd go a particular way it would be appreciated.
I have my OEM '09 shock, as well as that somewhat tired '13+ unit. I'm sure they aren't worth much as is.
If the '09 unit could be rebuilt for less than the cost of a new aftermarket unit, I would consider that. 45 minutes of online searching has resulted in me sending inquiries to the outfits listed below. Curious to see where this lands.
https://traxxion.com/product/oem-sho...-and-respring/
https://www.racetech.com/ProductSear...)%20Ninja/2009
Pro-Action Suspension | Motocross Suspension | Harley Shocks
Words to live by
post #2 of 25 Old 11-29-2019, 02:37 PM
Newyork's Avatar
Iíd look for a used Penske or JRI if I were you. Those could be had around that price point if you luck out.
There was a guy on here selling a JRI for $450 not too long ago if you search the classifieds maybe he still has it.
May 2018 ZX6R of the Month
Newyork is offline
post #3 of 25 Old 11-29-2019, 02:48 PM Thread Starter
because the '09 OEM unit has low and high speed compression damping, I'm hoping it's worth the effort of refreshing. If I buy a used high performance racing shock, it's going to need to be re-sprung, possibly re-valved; certainly refreshed..... That $400 shock is really a $600+ shock -- still, much less than a brand new Ohlins, etc. @ $1,200+
Words to live by
post #4 of 25 Old 11-29-2019, 04:16 PM
Newyork's Avatar
You are 100% correct most used shocks will need a refresh. That said I donít know enough about re-valving the stock stuff to say whether or not that would be worth doing but it certainly will be better than not doing anything.
Newyork is offline
post #5 of 25 Old 11-29-2019, 04:45 PM
I'll have my penske triple piggyback for sale next week after my last TD of this year. PM me if you're interested.
JL99
post #6 of 25 Old 11-29-2019, 05:11 PM Thread Starter
The '09 shock had 12K on it when I bought the bike. The owner before me was a hefty guy, with a gf to match. I'm sure the pair was over 400 lbs, and they had the suspension near the maximum settings as a result when I got it. So stiff my teeth clattered together, my vision was blurry at any speed. By the time I got another 10K on the bike, I had backed everything off enough to call it good enough, through the next 20K before both ends started to wallow and become more and more vague.
I hadn't ever noticed any significant changes, as a result of damper adjustments. When I rebuilt the fork at ~53K, it showed me that there was no damping control (remaining) on the rear shock. Lloyd suggested a newer used OEM shock could be an improvement, and that was definitely better than what was going on with the '09, by that point. The adjustments actually had an impact on shock behavior.
It's now at the max compression and rebound, and I can tell it's starting to lose ground.
If I can rebuild that '09, I would hope to get a couple of years of decent street performance out of it. 20-30K would be highly desirable. That would put the entire bike at near 90K, and is likely to be at the point where I would have replaced it with something else.
jd41 likes this.
Words to live by
post #7 of 25 Old 11-29-2019, 05:17 PM Thread Starter
PM'd
jd41 likes this.
Words to live by
post #8 of 25 Old 11-30-2019, 02:08 AM
I've heard great things about the JRi shocks: www.jrishocks.com
post #9 of 25 Old 11-30-2019, 09:25 AM
mmattockx's Avatar
I'm not sure this matters to your budget or not, but you should keep in mind that you can always sell any aftermarket shock for most of what you paid for it in a few years if necessary, getting much of the money back out of it.
+1. A used name brand is a great way to go for a bike that is a few years old where the racers have moved on and there are spares sitting in garages across the land. I lucked into an excellent condition cheap Ohlins for my 98 from a fellow member of an email list to replace the sacked OEM unit and it was a great upgrade.
Thanks for that, I hadn't heard of JRI before. I'm not seeing sport bike shocks on their site?
Mark
1998 ZX6R
2005 KTM 450EXC
1982 GS1100E
mmattockx is offline
post #10 of 25 Old 11-30-2019, 05:13 PM
Mark
Weird, I don't see the sportbike shocks on their site either, but I'm finding them from other distributors/sellers:
http://www.hardracing.com/JRIShocks.htm
https://www.computrackboston.com/Jri...ri-500-259.htm
post #11 of 25 Old 11-30-2019, 05:26 PM
JRI Shocks JRI Cartrrdge Kits JRI Suspension JRI
They are no longer making motorcycle shocks. I asked Hard Racing about it about a year ago and it was what they said.
JL99
post #12 of 25 Old 12-01-2019, 12:19 PM
Turtleface's Avatar
I Ride: '07 ZX6R
I was watching a Dave Moss suspension setup video, where the customer had a dying rear shock on some sort of 600 cc super sport. Dave’s advice was to pickup a used OEM unit, have it refreshed, and then swap it for the current one. Dave stated you get about 7-8k out of an oem, and to keep the old one, and just keep refreshing/swapping them out.
I don’t know how often a good aftermarket unit needs to be refreshed, but if it’s similar, it might be cheaper to go the oem route, unless your trying to shave seconds of a lap time.
Pretty sure I should look into this, as my rear hasn’t been touched in it’s nearly 75k mike life...
Turtleface is offline
post #13 of 25 Old 12-01-2019, 01:32 PM Thread Starter
Originally Posted by Turtleface View Post
I was watching a Dave Moss suspension setup video, where the customer had a dying rear shock on some sort of 600 cc super sport. Daveís advice was to pickup a used OEM unit, have it refreshed, and then swap it for the current one. Dave stated you get about 7-8k out of an oem, and to keep the old one, and just keep refreshing/swapping them out.
I donít know how often a good aftermarket unit needs to be refreshed, but if itís similar, it might be cheaper to go the oem route, unless your trying to shave seconds of a lap time.
Pretty sure I should look into this, as my rear hasnít been touched in itís nearly 75k mike life...
That's an option, if you can find someone to refresh the OEM unit..... I've got emails out to everyone I listed hyperlinks to, and have only gotten one response, to say that the company is shut down.
On Lloyd's advice, I went the route of buying a $57 used OEM shock from '13+, and it's a marked improvement over the sacked out '09 shock. If I could send the '09 out to be refreshed, I would certainly go that route as I won't be 'down' while that work happens.
I'm even considering what it would take to gather the tools to learn how to do it myself. Hardest part seems to be recharging the shock with high pressure nitrogen ( I could do that at work ).
Words to live by
post #14 of 25 Old 12-01-2019, 02:38 PM Thread Starter
Has anyone used EPM in NJ for suspension work?
Motorcycle Shock Rebuild Service - EPM Performance Imports
Words to live by
post #15 of 25 Old 12-01-2019, 03:30 PM Thread Starter
How about Cogent Dynamics?
https://www.motocd.com/contact-us/
Words to live by
