Well that is unsettling. I took the stem head off this morning, not expecting the ignition bolts to be filled in and ground down a tiny bit. I assume that is some anti theft thing Kawasaki did at the factory. However, they still seemed seated tightly and not loose, so I'm now assuming the plastic assembly is damaged. The manual says to use a chisel or punch to turn that bolt out.... but I think i'm just going to drill it out and use a torx bit. This might end up being one of my new winter projects that I'll do.
They are tamper proof bolts, the head breaks off once you tighten them, they also are red loctited in place, so while drilling out to the bolt head gets you easy access to remove the ignition from the top troiple- you then should apply heat and grab the stub with a vice grip to unscrew them instead of trying to drill them out completly
but if the bolts are tight the body of the ignition should also be tight........
Is the base cracked or is it just the internals that are loose inside the body
