'05 636 - ZX6R Forum
post #1 of 2 Old 09-10-2019, 09:33 PM Thread Starter
'05 636
the bike had water in fuel. tank drained-flushed-checked fuel pump, refilled with clean gas. everything ok! but now it cranks for maybe a minute till it finally runs by itself. once it has been started it will fire on the second or third rev like it should. but cold starts take a lot of cranking ! any advice would be greatly appreciated ! i have replaced primary fuel line, no difference. maybe injectors have trapped air - need to be bled ? primed ?
timpull22 is offline
post #2 of 2 Old 09-10-2019, 11:06 PM
Presuming that this was not the case before?
I'd check the stick coils, then the plugs, then the valve clearances....
Words to live by
