Doesnt like starting when hot... sometimes ('99) - ZX6R Forum
post #1 of 3 Old 09-09-2019, 02:53 AM Thread Starter
KevAmiga's Avatar
Question Doesnt like starting when hot... sometimes ('99)
Bit of an odd one, sometimes my ninja is hard to start.. seems worse if its hot OR, if you start it, run it for a short time and switch off, then try to restart (for example, i stopped to fuel up the other day and she wouldn't go).
Before i start pulling things apart, is there anything common that causes it? I have noticed one of the terminals on the battery is getting a bit "fluffy" with white deposits but, it doesn't seem to be causing issues with the starter running slow or anything... she starts on the button first time every morning...
Cheers!
Kev
99 ZX6R / 2016 Montessa Cota
KevAmiga is offline
post #2 of 3 Old 09-09-2019, 05:22 PM
Brandon35's Avatar
Try running a full tank of gas with a good amount of seafoam in it. Look for non-ethanol fuels when you can and make sure your choke is on and idle screw has her purring between 1300-1500rpm
Brandon35 is offline
post #3 of 3 Old 09-09-2019, 05:23 PM
Brandon35's Avatar
After that you’ll want to look and see if you have junk in your air-box and if that air filter needs replacement.
